+++white Face Dials @ Bezels+++ Get In Now
  • Replies 271
Posted Images
Update on my situation. Kezza finally got me 5th blue LED which is great. Got all 5 in today, they do NOT evenly illuminate the cluster.. almost do, but not quite. The top of the speedo is duller than everywhere else, i think thats what, the 80-100-120 area? Anyway, not happy about that.
And whats worse, is the holes in the dials for that thing to poke out to stop the needle going below 0... well, it does NOT line up. So not only have i knocked my needles around because of this thing thinking i had done something wrong that they didnt line up, but they definitely dont line up and freaking blue light escapes through where they DO sit. And my needles dont have a stopper.
And im still waiting on my metallic bezel.
AND the blue LEDs lighting up the Blue MET dials doesnt look very good either to me. I'll give it a week or 2 but dead set what i have is totally not as i was led to believe, it must be the wrong product just like the bezel i got and sent back because it does NOT line up. Basically everything i've gotten has been crap and wrong. Waste of $300 and 6 months. :D
Seems like although kezza was the local guy fronting this thing the guy in japan doing all the product side was "j-styleinc2004" - He is the bloke that has sent us the wrong shit. ie send me s1 bezels and dials instead of s2!
j-styleinc2004, please come on here and address our issues you have taken money and delivered the wrong goods.
Ok so after months waiting i finally get the fifth blue LED... wel it has died after being in for 2 weeks! So basically the other 4 are now useless, the dials were not right (holes wrong spot), and the bezel was for s1. $300+ spent, all unuseable or stuffed.
Thing is, i was happy with just getting the LEDs working, now i've got nothing at all.
I am so demoralised and unhappy i cant describe. So much stuffing around and effort and im worse off than when i started.
only got 4 leds with mine
Same thing happened to me, took months to get 5th one. And 2 weeks afterwards it died.... 2 weeks after that, another LED died. Pretty shocking! Im going to rip them all out... probably all die before i get around too it aswell!
Wtf? leds died? they must be shit! I've never had an led die on me.
Their life is normally so long that they don't blow - that's meant to be the idea anyways.
They have ALL died except the one on the very far right. Yeah... sensational. Past week i have been driving around unable to see how fast im going at night and in the mornings. Thanks group buy! :stupid:
I've pmed kezza before, no reply. Tried calling his mobile, but it seems disconnected. He has been active on the site though, just not responding. He's been active july this year.
Shoot him a pm for us mate, just in case if mine didn't go through. He's still got my bezel and dial.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
