Ok. My hole was cut with a hole saw and was done by a proper mechanic (Benny from BMT) I would need to get a certificate from him in order to pass a defect per say?
It looks factory... do you reckon I'd get off otherwise?
post-25470-1163129107.jpgthis is the bracket he made up. its not even welded in just three bolts. but oh well ive got the paper work at least. cant be harrased about it ever again.
that's not so neat :yes: and now it's safe? bah!
cheers to you mr crust for making an effort which i might just rely on some time :P
I would be intrested to talk to someone who knows the ADR's properly and can give me a definate answer
like most laws they are always vague and open up to difference of interpretation
cop pettet says this/engineer bob says that
which is right?
most ppl with a brain would know that a guard liner would indeed know that it is in no way a structial peice of the car ...
most of the front end isnt even structial, most of it unbolts and u could go until u you a motor and chasis rails, good stuff :huh:
well most people seem to worry that cutting a whole in the skirt effects the airbags, but the engineers who so called make this mod legal, only put on a dodgy looking patch and it passes and no one questions its effect on the airbag, true?
looking at that patch, can anyone give a true reason how that makes
the car any safer ?
Personally looking at the top bracket its pretty dodgy looking and in no way does it strengthen the body, as a car is only as stong as its weakest point, now if the rest of the skirt is 1mm thin and the patch is lets say 3mm in the case of an accident the skirt will still get damaged and that bracket will sit in place and have no effect.
unless benny is certified to clear defects, even the most perfect job he does will be defected.
  • 1 month later...
i would retract that statement is he certified? if so ahahahahaha
anyway only engineers can pass this
If i ever get around too it, i'll take a pic of the hole that has been cut in my gaurd for CAI.
Its been re-inforced with solid steel all around the edge of the cut so it will pass an Engineers once im completed with the conversion.
You'll see a proper job isnt exactly easy :wave:
You know what the funny thing is though. On the top of the engineers cert is says it is valid for 30 days. Does this mean a cop can f**k you over again 30 days after you got it done?
Note my reply here http://www.skylinesaustralia.com/forums/in...p;#entry2798167
What is interesting is what the "Act" states exactly as the VSI's are specific on requiring a certificate for any panel cutting forward of the firewall.
Anyone know the rules on number plates. I have them mounted slightly on the side of the car and got fined and lost 3 point because of it. Any links? Lol i might not have a licence because I have my number plates mounted to the side :P Fkn BS
Drivers of a lot of cars like cheater EVO's and Alfa's would be in a lot of trouble, I'd question it.
  • 5 weeks later...
hey all!
im looking for the document that tells u wat is legal and wat is not to modify in your car (in NSW). ....where can i find it? or what is it calld (so that i can find it..)
cheers
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
    • Also this is my garage ornament 😁
    • @TurboTapin hey man thank you for all the info! I am about to order my cd00a today for a rb25 neo s15 build I am currently trying to get the ball rolling again on 😁 what is wrong with the Collin’s adapter? Is the bellhousing machining 15mm because that’s how thick the Collin’s adapter is or is that universal across any I decide to go with? Also do you recommend any adapter in particular? Thanks man 😃
