Hi everyone,
I did a quick search for “oil pressure” but as I am posting under major panic I didn’t come across anything that was relevant to my problem.
As I am currently running my motor in (trying to clock up 500km) I have notice oil pressure drop. I realize that a bit of drop is ok but today when I was at the lights I noticed that the pressure was getting awfully close to 0 on my oil pressure gauge and kept hovering below 2. As I pulled into my driveway I notice the gauge went right down to 0. I quickly switched the engine off to prevent any damage.
My question to the general populus here in FI section is: Is this a normal occurrence? Can anyone hazard a guess to what the problem might be?
Any help will be greatly appreciated.
https://www.sau.com.au/forums/topic/142836-oil-pressure-getting-close-to-0/
is the "low oil pressure light" on?
No light isn't on.
get an aftermarket gauge.. 1/100th of the price of a new engine
You are right; I'm going to look in to getting one now
before you do anything else, get yourself a new oil pressure sender unit.
Do you believe my sender could be shot? If so I’ll get one from Nissan.
if its an r32 then it very well could be.
it seems to be a common problem with them.
and as Waz has stated, getting an aftermarket gauge is best (but you'll need a sandwich plate etc). so go with the new sender unit first.
try spray the sender unit with that contact cleaner stuff..
after my engine was put bak in my car i had a similar thing.. when the car was hot the oil needle would sit on like 1psi at random times. the sender unit was all oily and decrepid looking.
go have a read on www.aus300zx.com in the technical pages.. they have a big writeup about changing the OPS (oil pressure sender unit)
many of them changed their unit only to have it fail again after 6 months...
my setup:
gauge (ebay) comes with sender unit - $30-60 depending on what brand
sandwich plate - $25 from justjap
i mounted it in the glovebox. still can use the stock gauge for hte oil pressure warning light (which is accurate)
plus its WAY more accurate than the stock gauge
good investment me thinks
Yeh i had the same problem and i shit myself, on idle after driving for a long time it would drop to just above 1 on the guage but the light didnt come on which was good.
But then i used different oil and it doesnt do it anymore haha, still gets low sometimes though.
I think most 32s have shotty oil pressure guages.
BTW new engine as well with 1,000km on it. New guage is on the agenda.
Thanks everyone for all your help.
I purchased an Autometer oil pressure gauge that I am going to install tomorrow. I'll let you all know if it works. Just one last question though, at what PSI should my oil pressure gauge be reading at idle?
When cold ive seen it around approx 70 psi at idle
When warm around approx 24-25 psi at idle
Thanks champ! I'll use that as a reference point
Please be aware, the standard nissan oil pressure guage reads in KG/cm^2 not PSi.
Yea, I have disconnected the standard one now and installing the Autometer which is in PSI. Thanks for the heads up though!
Cheers
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
