Hi Lads,
Rex Has his KingPinny 'budget hack' on the Dyno the other day for its post-build, pre-thrash checkup. It makes respectable grunt with AFR's sticking nicely between 12.3 and 11:1 for the whole run.
However at the top of the run just prior to limiter (perhaps 500rpm) the AFR suddenly makes a dead vertical up past 14:1 which is where the operator jumps off the acceleratix. We repeated the run three times, peak power was within 2-3rwkw and the same massive sudden vertical leanout condition.
The dyno was done as a favour so no fault finding was performed, Rex was thinking that perhaps the AFM may be faulty (NIssan's are renowned for them) causing the ECU to basically drop the injector duty cycle right off.
The engine R32 RB20DET and is stock, along with the ECU and turbo etc. Only modifications are filter, exhaust and intercooler setup. Boost is un-modified but up to 11psi due to removal of restrictions in pipework etc.
Rex has considered AFM maxing however it seems more likely that Mr ECU would just go massively rich safety-like instead of lean.
Anyone seen/heard similar problems? He has seen a couple of other graphs with the same problem, but not an explanation.
Rex has some diagnosis to do on Mondey such as AFM peak voltage etc, but would be good to have some things to check if He runs dry ideas wise. It also seems very unlikey to be a fuelling issue because of the shape of the graph.
Have included printout below if it helps...
Thanks Lads
Rex
https://www.sau.com.au/forums/topic/142860-massive-sudden-lean-out-rb20det/
Rex considered fuel pump not to be the problem because surely if pressure couldn't be maintained the AFR would rise gradually. PUMP is R32 GTR
Fuel injectors maybe, but supposedly they are good for 230odd rwkw at 100% DutyCycle. HOWEVER with stock reg, He knows not.
Sounds like Rex may need a slightly different Multimeter...
As for the power, trust Him, Rex cannot believe it either. Approx 140rwkw would've been a delight but the 192.6rwkw peak almost made Rex pass-out.
Edited by Rex_Kelway
Injector size: 270 cc/min injectors(25.7 lbs/hour)
Number of injectors: 6
BSFC: 0.65
Duty cycle: 100%
This combination will supply fuel for 237 horsepower
237hp = 182kw...
I knew this was going to happen, believe Rex he has heard it muchly since the day it was dyno'ed.
The engine is approx 60,000kms ex-GTS4 R32 from around 1993 He believes. Wether or not they use a different turbo (M-spec or whatever??) He knows not, but it IS the turbo that came in the half-cut. On Mondey he shall get serial no's to confirm.
Rex works for an importer, and yanked the motor out himself.
The car was 100% stock, no filter not even a timer or boost gauge. all of the factory bolts/sheilds/gaskets/retainers were in place with no signs of ever have being removed. Thats whay leads Rex to believe its stock.
Believe it or not the turbo is not the 'be all and end all' of the intake system. It is VERY dependant on the systems around it.
This was designed to be a help diagnose thread, not a 'you're a liar' thread. The Dyno may be wrong, but the operator has done it a thousand times. The car does feel that fast.
Back to the problem...
Fuel pressure shall be checked on Mondey to be sure
no one is calling anyone a liar. the figures quoted are at the top end of the believable scale.
all we are doing is trying to help diagnose a problem. if you get as many suggestions as possible, you can eleminate them one by one.
craig
Yep, maybe a bit premature ;) ...
Rex is just geared for the 'Thats too much power, its impossible...You're a liar!!!' arguement that is likely to follow that printout and specs list.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
