  • Replies 251
rb25 auto awd - front driveshaft pulled for rwd dyno
249rwkw at 17/16psi 3rd gear
Garrett GT3076 700177-5015 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
60mm diameter 84-trim GT30 turbine and 76mm diameter 7/14 bladed compressor wheel in 56.9-trim
JDM S15 Silvia 450/480cc injectors
z32 afm, tomei head, 3" exhaust, remap
I used a Dynapack hub dyno, they read higher than DD - its not magically higher but enough to make a difference. I don't know what the difference is, the one I did 300kw on is thought of by a few (who are used to Dynapacks) consider it a heart breaker for hub dynos but still no DD style heart breaker.
I know this is probably annoying for you, honestly it was for me too and its all my fault - so sorry about this. I have never removed the PRV as I don't have some vacuum hose long enough to reach from the wastegate to the boost source... the PRV has been spliced into my old one since I got it. I went and grabbed some the other day and went to put it on for the dyno tune (which was booked at the last moment) and found it didn't fit. The result of that is the PRV keeps snapping open and closed and stuffing up the boost curve and makes it not a realistic representation :D
For what its worth, when the PRV settles down the boost holds very very stable - I am going to get some vacuum hose that suits and am being hassled into putting my car on a dyno day in a couple of weeks so may end up just giving in to that without the valve and seeing what that does to the curve. I'll post the boost plot from that :happy: I didn't even bother getting this one printed.
Its definitely going to make it build less, not more aggressively when I remove it - the curve will be more consistant. Strangely it doesn't seem to behave the way it appeared to on the dyno on the road.... Not sure what was up with that.
  • 2 months later...
just read through most of this thread, some very informative stuff in here!
seems there is not much love for the 3071 .82; is the 3076 .82 really that much better for someone chasing 260-270rwkw?
3076 .82 would be the way to go. you will get bored with 270rwkw. atleast with the 3076 you have some more power left in it.
my 3076 makes 335rwkw on e85.
Good to see this thread still going! I see it a lot when I am googleing.
how do some of u guys get over 300kw with only 17psi on 3076r? hmmmm
I made 314rwkw on 18psi with water methanol injection. Torque was 720nm from 3000rpm all the way to the limiter.
mods:
Garrett GT3076, 0.6 compressor cover, 0.63 rear housing
Powerfc (Tuned by me)
Water Methanol Injection
Standard Engine
Standard Manifolds
Front mount Intercooler
Big Exhaust
Nismo 555cc Injectors
Standard FPR
Nismo 275lph In tank pump
They aren't really that great. Better off with a GT3076 with a 0.63 rear.
I'll be keen to test that with the RB30.
what would be the difference in response though?
not with a 0.63 rear.
I have a like new 0.63 internal gate rear housing for sale if anybody wants it, and a dump pipe to cat to suit. I'm unloading it because I have a RB2530 and the 0.63 rear might be fun, but is a little too restrictive for the RB30s extra breathing.
Sale thread here:
http://www.skylinesaustralia.com/forums/Rb...ml#entry5264403
  • 6 months later...
i'm looking at buying one of these
700177-5007
gt3076R
external gate
front trim 56, .60 ar front surge slotted
.84 rear trim, .82 4 bolt rear
i have the option of the .60 or .70 front
is tthere going to be much difference?
my combination at the moment is a standard rb25det
Ive got a 6boost and plazmaman
was recently making 300rwkw on a standard exhaust manifold. 3076R.70 front. .82 rear internal gated
i
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
