pm pkblade on here about other stickers, i was selling these for him when he couldnt make to an event a while back and these are whats left over. They are the SAU website and fit perfectly in a rear 1/4 window.
Cheers mate! can u PM me ur location and number so I'd like to go to have a look!
After R34 GTT SMIC in good nic. Northern suburbs preferred. PM me.
Edit: Also interested in a R32 GTST wastgate actuator.
Got myself a SMIC....................Thanks Howie :wub:
Still looking for an actuator - anyone?
Edit: R32 actuator
Edited by Stevodm
just got some new rims priced up (18x9 & 19x11) with street legal semi slicks and i dont want to get them but i do haha
if someone can come up with some 33 or 34 gtr rims before i go ahead with these other rims that would be great (for me and my bank account!)
in other words, wtb 33 or 34 gtr rims!
:wub:
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
