After the plastic steering column trim/surround with the ignition barrel piece for an R33 S2 (I heard series S1's are slightly different and don't fit) in good condition, no screw holes etc.
Looking for a standard RB25DET plenum.
Does not need to be in great condition on the outside as I am just going to see what they look like polished :)
Don't want to pay heaps... Maybe you have one just collecting dust :)
PM or reply to thread.
Items:
After a MANUAL RB20DET gearbox. Must me in Good working condition. no rattles whines etc. all synchros good etc
Extra Info:
may also be interested in a Rb25 box if the price is right. also willing to pay more for a rebuilt RB20DET box (with proof of rebuild)
Contact Details:
I'm not on the net much due to Uni. best way to contact me is via TXT on 0416 580 223
Price and price conditions:
Let me know what you have, what condition it is in, and how much you are after for it. also have a set of R32 GTR wheels with tyres that i may be willing to include in some form of transaction
Edited by CRSKmD
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
