Hi guys I'm after a R34 gtt nistune ecu..went to go get one tuned to only find out it was a random jap spec dud! :/ car is at tuners still and I need one urgently. If anyone has one or knows someone that's looking to sell, let me know ASAP 0432145854 cheers
Wanted. Earthing/Grounding kit, Prefer GTR but any Skyline model will do
cheers Mike
I might have a set in the shed or I could make a set then they are the right length
Wanted
R32 skyline (coupe) Rear bar – Silver
R32 skyline (coupe) rear bar support
R32 skyline tail-light surrounds (silver)
These bits will allow me to make it out for SAU nationals, after overcooking it at Legend of the Lakes finals on Sunday :(
he guys im after a r32 drivers side exterior window channel that the seal sits in and runs up the a pillar and across the roof ( picture below to help) must be in good condition with no dents etc
let me know if you have one spare
cheers will
You'll be hard pressed to find that bit in decent condition on any car in aus. That rubber strip decays superfast in our climate and they cost around $650 new from Nissan (If anyone can source them cheap, please do let me know)
I want to replace mine too, but they're super expensive and I've been looking for 2 years and found squat.
-D
