I'm about to have my car repaired at M&C Doyle in the next few weeks pleanty of guys recommended them. Do a search for crash repairers on here & check out this thead:
http://www.skylinesaustralia.com/forums/in...96&hl=Doyle
https://www.sau.com.au/forums/topic/143880-crash-repairer/#findComment-2684786
Boswell Panel - located on Ware st at theberton, right near weat thebby hotel. John is the guy that owns and runs the workshop. He painted my car and have no complaints. he loves CA$H too.....
I wouldnt recommend him is he wasnt first class.
https://www.sau.com.au/forums/topic/143880-crash-repairer/#findComment-2687349
Countless mitsubishi Veradas, magnas, 380s, as well as hard to fix Eunos 500 (my car) was fixed at Roger Steen Crash Repairs. at Glynde. did a suberb job. i highly recomend them. They do a shitload of other cars too, so i suggest going to them and getting a quote. you get warrantee like most places on the repair and its RAA approved repairer which is also a nice little peace of mind.http://www.motorpoint.com.au/autobusinesse...airs-Glynde.asp
them or st. peters crash repairs. these 2 places are govt car regulars. they know what they are doing and know how to price a repair.
Edited by SAZilla
https://www.sau.com.au/forums/topic/143880-crash-repairer/#findComment-2687521
lol Maxx.
You wouldn't want to mention the issue/ripped off you had with a well known crash repairer otherwise they will threaten you with legal action again. :(
EDIT: Another vote for provident.
lol :(
"maybe" it's not a ripoff nor second quality job, but i am too picky compare to most silvia boys :)
Edited by Maxx
https://www.sau.com.au/forums/topic/143880-crash-repairer/#findComment-2687736
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
