Hi Guys,
I got an R33, RB25DET - the gearbox is whirring in 2nd, 3rd and 5th. Replaced the oil and all that - and its starting to get louder and louder! Ugh! (more $$$)
Here's my plan, help me out here tell me if its a shit idea or not.
1. Buy Good RB20 Gearbox cheap
2. Remove RB25 shagged box
3. Replace with RB20 Box.
4. Fix/Rebuild Gearbox as time/research/money permits.
5. Swap rebuilt RB25 with RB20 box again.
6. Sell RB20 Box cheap
I'm not pushing super-hp yet, but will be around the 350+rwhp after turbo upgrade soon, so the RB20box has to hold the standard 270-280hp that I've got now.
Installation considerations - I got access to workshop/hoist etc. I know the R33 boxes are heavy (like 70kg) so I'll get a few mates in on the deal.
I just need to make sure that EVERYTHING bolts up to the RB20 box, bellhousing, drive shaft, shifter, clutch slave cylinder etc.... Anyone done this before?
Cheers guys
-Kym.
https://www.sau.com.au/forums/topic/143952-r33-gearbox-project/
in R31's, you need to modify the tailshaft to fit the rb25det box, not sure about the gearbox crossmember. could end up being a bit of stuffing around.
might be a better idea to buy an RB25 box, even if its an NA one, because the resale will be fine and it will bolt straight in.
basically you'll need a different one
all the rooting around will cost you near on HALF of what the box itself will cost to rebuild.
if you drive it like a grandma till you can rebuild it, you'll save a good $700 in the long run
Mate,
i'm no expert here but it sounds like you got a little ripped off! They reckon $4000 for a rebuild?? What the hell are they putting in it??
JUSTJAP sell new ones for $3200.. i bought one of them instead of rebuilding as it was cheaper! i think it was 4000 for the rebuild. dont hold me to it thow
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
