hey there guys i am a bit concern that my hand brake is not locking the wheels up. when car has stoped the hand brake still stops my car from moving its just when i pull it up when moving they dont lock. i do clutch in and i have adjusted them too.
i probally havnt adjusted them right but yeah, any help will be great
thanks
https://www.sau.com.au/forums/topic/144332-hand-brake-not-locking/
Have you checked the handbrake shoes?
Proper way to adjust handbrake is to back it right off at the lever, then tighten it all the way at the drums so it doesn't move, and then back it off 4-5 clicks. Then tighten the lever up till it locks after 5-6 clicks.
hehe my questions r for the benefit of myself and the other stupid ppl to scared to ask :O
any question you ask is stupid justin, hehehe.
the handbrake mechanism is in behind the rear rotors. you pull the rotors off to expose them.
you said you only wanted a pic of the drums shoes :(, anyway heres the Translated version. if there is still plently of meat left on the drum shoes but they have a glazed surface just do what Snowman said. if they are on the skinny side of things replace them, on that note anyone know where to get drum shoes and what price they are?
you said you only wanted a pic of the drums shoes :rofl:, anyway heres the Translated version. if there is still plently of meat left on the drum shoes but they have a glazed surface just do what Snowman said. if they are on the skinny side of things replace them, on that note anyone know where to get drum shoes and what price they are?
from the page:
"You do not know why is, but R31 (the Indian ram system) the emergency brake works like the ogre"
hahahahahahahah!!!! :laugh:
URAS make an awesome upgraded handbrake shoe for Skylines - if you plan on doing a fair bit of handbrake stuff for either drifting or motokhana's/autocross. I use them and they make a big difference over the standard shoes.
http://www.uras.com.au/
For stock ones you are probably better off at a wreckers. From what I gather it's one size fits all for skylines.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
