Picked up car - was raped by wharfies!
I picked up my car today from the wharf. i was very excited but i knew that some stuff would be stolen. these are the things that were taken:
monster tacho with shift light.
razo pedals
front fog lights
when taking the tacho they even pulled out all the wiring that went into the dash so now i have a nice hole next to my steering wheel.
also the car had done 10ks since being cleared off the boat. i know it gets driven a little bit but 10ks is going to be a sh*t load of laps of that place!
i know that these are insignificant things but still they were mine and its just annoying.
on another note the car is running VERY rich and went through 1/4 tank in about 40ks. its also not very quick and there is something wrong when it hits boost. but these things will be fixed after i get it back from compliance.
was origanally going to change the trust front bar back to standard so that i can lower it more, but the exhaust is sitting really low to the ground so there goes that plan.
hopefully ill be out and about soon...
https://www.sau.com.au/forums/topic/14472-picked-up-car-was-raped-by-wharfies/
  • Replies 53
ooooooooo nice one! :D
damn wharfies.... u should be able to sue em for compensation on what theyve done to it... was it insured while it was being shipped? if so u should get all those bits back.
PS. cant wait to see it!!
when i picked it up the fuel light was on, probably the only reason why they stopped driving it.
no it didnt have insurance cause geoff told me that you cant get it far car carrying ship. plus i think that it only covers loss of vehicle, sinking etc.
yeah it does suck about the gauges, not that i wanted the tacho but i would have liked to at least tried the shift lite before i pulled it out.
looks like the beast will be going to get tinted with the group deal, unless ive missed it already.
mmm... definately go the FULL service before doing anything remotely stressing.
Got it done to mine when i got it and turns out the fuel filter was BROWN as. After oil change etc. etc. it was running that much nicer it was a different car.
Cause some have been sitting around for some months before getting here.
If any of the cars that i have sent had tellys or anything fancy...i take it out then stash it in th 1/4 panel or post it across....in regards to people driving yourcar...how sure are you of it???i dont think the guys that work there really have the time to drive the cars around...i mean if it was something special maybe even the i doubt it i doubt that anyone would have went out of there way to drive it...i mean its prob 1 of 20 skylines that were on that boat....i have shipped cars with full tanks...half and empty...it depends whats in it at the time of drop off
Originally posted by Geoffx-19
Hey, are you getting the car complied under the new legislation?
How much does this cost and where are you getting it done?
Oh yeah what type of car is it? I assume it's a skyline.
nah its under the old system. probably the very last one being done...
yeah its a 32 gtst
Originally posted by R31Nismoid
i've heard of a few people getting the detachables taken off and sent over in boxes separate to the actual car.
worth a thought for others.
Long story... but the car was moved from osaka to kobe for container ship but then ****en NAB (refer to my "dont borrow from NAB" thread in here) took too long and i had to change it to a car ship and the buyer couldnt get back to it to be able to take the stuff out. :)
one good thing about the theiving wharfies is that they dont take stuff that will affect you driving it. eg, they left the boost gauge which was on the same mount as the tacho, plus left the turbo timer, boost controller and vpc.
Make sure u do a full serive on the car, plugs, oil, oil filter, fuel filter, replace gearbox and diff oils also before u go floging it around.
they change all fluids at compliance if you get it done somewhere with a clue.
and i know several of the guys on the P&O docks in sydney that get plenty of time to cain the sphincter out of the imports when they take em off.
i dont know, maybe they were fooled by the 4 inch intake into the 2835R...
While you are doing the 1st service/compliance i would also change the timing belt.
Congratulations on your ride!
It is safer to transporta car with a full tank, as fuel vapours are more likely to blow than the fuel itself. Thats why at indoor car shows you must have a full tank of gas.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
