V-spec came with slightly harder suspension and active rear diff.
When you upgrade the suspension there is no difference, and since they are getting old that is almost a necessity.
The active diff is poo if it stops working and is no faster anywhere while the std has a nicely setup 2-way LSD.
On R34 it has underbody diffusers and a deeper front lip.
On R32 it has Brembos and nicer 17" wheels.
Don't waste money on V-spec unless R34.
This was covered a month ago.
Can anyone 100% confirm this?
Is it possible that a Series II only got the red trimming on the seats but, no Xenons? if in fact this is true, is there a way of adding Xenon lights in the future?
Only series III got xenons.
You can add them sure. $2000.
32 vspec 2 might b worth it, and brembos were certainly a worthy upgrade for a 32.
owning an active lsd that hasnt mess'd yet i can tell you, its slightly more everyday friendly but still locks efficiently until it blows, then its supposed to be expensive..... let you know if i ever blow mine but considering i dont do burnouts mine should prolly last 4 yonks considering my car wont ever make enough power to exceed it's limitations... i think
Serious II? Must be a limited model *S* jk
frankxinyu, Whats the difference in driveabilty V-Spec Vs Std GTR?
haha i dont know what i was thinking...haha spelling fixed.
i have not driven a normal R33 GTR, so i couldnt tell u sorry. but as ppl sated, there are some minor difference
Yes it is if someone has changed them, only series III had red seats. You can fit xenons to any 33 GTR ( with a slight mod) but they are very expensive even second hand in Japan. Halogens are O.K. as long as they are not converted xenons and you can make them a lot brighter by feeding 14 volts to them direct and use a rely to trigger them on.
There are a few little other differences in the series III as well. the front lip is different ( lower ) than S II and S I and the brake ducts are thicker. The front passengers blinker /vent is different , the fuse box cover has GTR on it, thats all i can think of now but i'm sure i missed something .
As Geoff said the struts are harder and about 5mm lower than none V-spec, Attessa pro, ALSD and the cluster and finned diff.
the series II gtr i am buying has red stiching in the front and rear seats?
http://www.skylinesaustralia.com/forums/in...howtopic=145115
Dude if this is the car , looks like its a series II with series III seats, looks like its not a V-spec either.
I knew i forgot something series III cars have a rear fog light as well, so only one reversing light.
That is definitely NOT the car I am buying!
The car I am buying is a 97 GTR V-Spec with the LSD light on the dash, red stiching on both the front seats and rear seats and also has a red reverse light on the RH rear of the car.
Well thats probably a series III with the xenons removed for compliance . How long has it been in the country? The reason i ask is because under the old system you wouldn't have to remove the xenons, only under sevs . Have a look at the front lip/brake ducts and the front left ( passengers side)blinker grill, as i said they are different in the III, what about the fuse box cover? What month 97 ?
The red light is NOT reverse light, its a fog light.
I'm currently looking at a 96 model 33 GTR V-spec and it has Xenons (listed as factory in the sale info), am I to believe that these are not genuine? The pictures certainly show Xenons.
Back to the topic,
My understanding of main V-Spec differences were,
ATTESA E-TS PRO
10mm lower and firmer suspension
Active LSD
LSD and ATTESA Pro combine to allow torque split left and right as well as front to back ike a standard GTR. It seems to be a big debate about it's merit.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
