After getting a 4 wheel balance + 4 wheel alignment done the results were, that one of my hubs are bent. The suspension place stated that a castor kit would be the cheapest method of fixing the problem.
My question is where could i find and how much would a hub cost for a 1993 r32 gtst?
and how much would it cost to fit?
Would it be better to repair my hub, buy a new/second hand one or castor kit?
I didnt catch which hub was bent and have attached wheel alignment results.
He also recommended to purchase a camber kit.
If anyone else can spot any issues with the above results, please post away :P
Thanks for the help :P
- Patrick
https://www.sau.com.au/forums/topic/145731-bent-hub-what-to-do/
For the camber and castor kits, try the Whiteline/Bilstein Groupbuy
Except the camber kit is now $187 instead of $277 (from memory, has gone down a fair bit in price though)
From those specs I would guess that it is the left upper control arm that has a problem
Edited by salad
agreed, or lower control arm. its very unlikely to be the hub itself. why is the caster shown as 0 after adjustment....did they actually measure it?
yeah i'm a bit dubious on the 0 degrees caster after adjustment, that is not ideal. although I'm guessing as it's non-adjustable maybe they dont bother with the after measurement and it's still the same as before. not sure on the rear toe out either, it doesn't seem desirable to me.
I'd be leaning more towards upper as both caster and camber are out by a fair bit. Lower control arm has to move back a decent amount to decrease 1deg, and the radius rod will stop this, it cant really stretch.
He actually has 4.1mm toe in. It does seem high though, but wheel aligners do this alot to counter excessive camber wear.
Edited by salad
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
