  • Replies 152
If i can still get a set of whhite/red/silver nismo stripes i will take some, pm me if you can get em
I can still place an extra one for you, please see how to pay on first post.
How's the order coming along?
Due to end of the year thing, work load....etc..there is a slight delay but i'm working on it.
Cheers
Update!
Words are they will be here sometimes next week, there was a slight delay due to the long break but apart from that everything is back on track now.
Lots of people pm me ask if they can still join the group buy but now its a little bit too late though my supplier has no problems making more for us so i *might* start another group buy if i'm motivate enough lol.
Update!
Awesome stuff West! Keep up the great work.
Any more west, let me know ay?
I'll see what i can do for you mate.
I get TNT docs pretty much every weeks from my supplier (work relate stuffs), i'll see if she can order me another one and slip it together.
Also guys, stickers has been made, getting pick up today and send out tomorrow. I dont know how long though, latest is Monday i reckon. Earliest is Friday.
Cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
