hey all
i own a hr31 skyline and recently purchased a r32 gts4 4door skyline with a rb26.
i would like to do a bit of track work every now and again to really open her up!
the car has stock brakes at the moment and i really want to ugrade them but without spending anymore than $1500.
the car aslo has ABS
are r33 brakes much of an upgrade?
would the lines match up properly for the GTS-4?
could u guys tell me a good setup without goin over my budget of $1500?
thanks
luke
you could go with R33 GTS-t front rotors and calipers if you wanted... they are the same diameter (296mm) as R32 GTR (non-brembo) but are 2mm narrower in width (30mm as opposed to 32mm i believe).
not sure if you'll need to modify your lines or not... it's quite possible though.
to be honest, i can't really fault the standard R32 brakes (although with slotted DBA4000 rotors) on the track, with some good fluid and good pads, but i don't have as much power as you would, so it could be a different kettle of fish.
I have a RB25DET in my GTS4, pushing 180kW at all 4. What I've done with mine:
Slotted rotors all round.
Braided brake lines (probably the best mod) all round.
I used to have problems with pedal fade, but the braided lines seem to have almost eliminated that. Had a day at Simmons plains a while ago, and the brakes worked well all day.
And, if you keep the fluid fresh (ie change annually), it should pull up well all day, every day.
i don't see how changing to braided lines would help with fade resistance....
fade is to do with either boiling the brake fluid, or your pads not being of the right heat range and overheating basically.
braided lines addresses neither of these.
what it WILL give you, is a slightly solider pedal feel, as they will stop the line expanding/ballooning ever-so-slightly under hard braking. (though unless your standard rubber lines are very crap, you won't really notice the difference)
the Just Jap brakes are the best value for money by far. brand new 8 piston calipers on 356mm rotors with pads and braided lines for $2,200
http://www.skylinesaustralia.com/forums/in...howtopic=112347
I know you don't want to spend that much but nothing comes close to that price, I paid 1500 for used 4 spot brembos with used pads and used rotors a couple of years ago.
r33/34 gtr brembo brakes are the best bang for buck. dont waste your mony on slotted rotors n shit cos they do nothing for better braking.
you gotta get bigger discs.
but if thats out of your budget just use some really hi temp brake pads, such as sbs duel carbon or ds3000's. and good brake fluid
i'm REALLY dubious about these things, purely because they are an unknown entity...
they have not had rigorous testing, they are not proven, they are cheap, and (possibly) nasty...
i don't want to trust my car/my life to something that is unproven.....
duncan where was these 355mm rotors at?
I can't see it in that thread either, but they definately have them in stock I was going to get them instead.....but clearance to 17" rims I needed to run was a problem
i'm REALLY dubious about these things, purely because they are an unknown entity...they have not had rigorous testing, they are not proven, they are cheap, and (possibly) nasty...i don't want to trust my car/my life to something that is unproven.....
I agree with the concern, there is nothing more important than brakes. But its not right to say they are untested and unproven, they have been used on a heap of cars including track use.
I bought a set a few weeks back and will be running them on my race car on the track, and at Targa Tas next year.....I'll let you know if I have any problems. At least 3 other gtrs will be running them at Targa as well
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
