I have a fully built rb25det with 700hp t66 turbo.
tuned and built by the same company.
Why would they only want to run 20psi?
I am always reading about stock 25's running 20psi and built 25's running 22plus.
The car made 315rwkw on stock cams with that 20psi but i was just wondering why they dont want to lean on it any harder.
Also the car is a tad laggy with full boost hitting at 4900 it builds from 3500 though.(stock cams and gears though)
The rear housing is a .86 t04r flange housing.
Any input would be great cheers.
https://www.sau.com.au/forums/topic/146053-what-do-you-guys-reckon/
well, you kinda answered your own question...
Your using a 700hp turbo, its not going to make boost/power early in the RPM range. :)
My GT30 (stock head) was making 17psi by 4200rpm, your turbo is bigger again.
Cams might improve it a few hundred RPM, some tuning might aswell.
But as for why the workshop wont push it, have you thought of actually asking them this question?
I think they would be the best people to address the questions you ask here.
boost is enemy number 1.
they may be running your engine at a high compression ratio and have not put an agressive tune.
Say your running low ignition - this could be tuned later to have better timing advance which will give you lots more power at the same boost levels but at the same time you have think about how long the engine is going to last and the posibility of it detonating.
Seems to me the engine builder has put a safe tune in it and wants your engine to last because at the end of the day its there reputation on the line if something lets go.
If you ask them why and they wont give you a good enough reason then take it into your own hands and take it to another tuner and tell them to push the shit out of it.. just dont go running back to the builder and asking him to fix it.
You have stock cams which likely means stock springs and lifters.
Around 20psi is where you start to see the factory gear start to valve float.
float = bad. If you want to run more boost get cams and springs and probably lifters in there.
what youve got to ask yourself becides building the engine to run more boost...
...is, why do you want to run more boost? to make more power? or is it a boost figure you just wanna run (magic numbers are kinda pointless IMO)...
mainly reliability. fuels etc etc.
if i rana workshop i wouldnt build up a motor, hand over the keys and go hey, pump 2 bar thru it . sik mate sik.
is it a bush bearing turbo? mayby therre woried it might shag the trust bearing. with more boost.
Nothing like that at all i was just wondering why there are guys running 20psi through stock 25's and i spent alot on getting a strong motor built and it still only runs 20 psi.
I'm happy with how it goes 315rwkw is nothing to sneeze at even if it is a tad laggy but it should pull an 11 at over 120mph so im stoked.
i was just wondering what you guys thought.
Ill keep yas posted on what changes the cams and gears make,thanks.
maybe the workshop doesnt know you well enough...and therefore doesnt know your driving abilities, therefore are letting you take it easy...
although most people do fiddle with their boost controller from time to time, there is nothing stopping you from playing with settings if you wanted to.
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
