I need of a GTR bonnet in vic, my car is currently under the hammer and the shop decided that the damage to my bonnet was pretty much unfixable (stoopid CF bonnets) so i'm in need of a new one.. pref a GTR one :happy:. Anyone know any places that might have one?
https://www.sau.com.au/forums/topic/146500-in-need-of-a-gtr-bonnet/
Yeah there are a few up north :miner: sadly I need one pretty soon and further more i'm already getting the money sucked outta me :laugh: not sure I can fork out over 1000 :S.
Either a Carbon-fibre or good condition Aluminium Bonnet $1000 is about the right price.
You may be able to call Nissan....seeing they have the R32 Parts in stock....
Hope I have been of some help.
fark that Tekin, Beer Baron had a very good genuine alu one for around $600... I bought one off Bu5ter for $550ish.
$1K will almost get you a new Nissan bonnet.
No offence, but I think you need to get your facts straight before you give incorrect advice (which it seems you do alot of!)
Bonnet is in quite good nick.. slight tear in the fibre though :/. I wouldn't be surprised if that would be bannable although i'm told it would be fixable. Can try and dig up a photo for you.
Yeah I been looking at around 600 for a bonnet but nothing in Victoria lately otherwise I would have snapped it up. Couple of offers from interstate but postage is a nightmare. Cheers for assistance guys.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
