Love your wheels viet boi. Dammit I got the wrong ones!
Mines going wingless and low again this weekend
lol thanks, yeah pretty glad I got these wheels, heard they were hard to fine, and came with good offset.
wingless and low ftw
still more parts to add on really soon..
that's a really sweet line ... damnit, I just spent nearly $2k on a body kit and the car doesn't look nowhere near as hot as this one without a bodykit of any kind! ;) Oh and silver truly is the best colour .. as much as I like my black 34 it is truly and I mean TRULY a complete pain in the ass to keep clean. Whenever I wash it, it rains the next day ... maybe I could sell some rain to needy farmers by washing my car and traveling to drought areas.
Farking hell man that's a HOT ride .. its amazing how good it looks and it doesn't even have a bodykit!!! :P Now you're making me consider taking the wing off again. I keep falling in and out of love with the wingless look almost daily .. sometimes, it looks dodgey but then other times like this one, looks so friggin awesome.
More pics please from different angles! Guys any cheap way to remove wing without having to plug the holes?? I'm kinda broke and note sure if I'll like it so worried if I do take the wing off I might change my mind next day .. but since its a black car I dont think some sort of black rubber plugs would look too nasty until I decide ?? Whaddya reckon?
Cheers Guys, yeh its lowered already bro but i want coilovers, looks fairly low in the pics but the rear is bit high, theres a lot of gap between tyre and guard, plus easier on the shocks etc i think if i get better setup. but i want wheels first!! haha :(
Delta force im in the same boat as you. wana take the wing off but not keen on plugging up holes, but ur right, car is black so wont notice quite as much.. let me kno what u decide
P.S i clean my cars all the time and yes black is a lil bastard to clean.. but i love it! lol
awesome ... but it'd be just that much more awesome in just about any other colour (silver, grey, blue or black) - not a fan of white myself
I think Millenium Jade looks the best for Nur's as it was the colour to come out of the factory like that.
its amazing how good the factory nissan wheels look on a black R34 .. I say, either get some reeeeeallly nice wheels or stick with those :P So many people spend money on aftermarket wheels (myself included) that don't look anywhere as good as the stockies
got couple PM's asking about more pictures, so went beach today with a mate and she started snapping away.
and this picture was awhile ago when i was getting parts installed..looks so good on the hoist.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
