No mods done to any of the guards. Doesn't scrub either :ermm: ..
Domo protects my car while while I'm at uni all day lol
Btw whats poke?
I don't think that +12s would be able to fit the front of a GTT without guard work.
Other GTT owners? example of your offset/pics as well.
Poke, like said, rims poking out of the guards.
Domo does the same for me. Angry little F*cker.
Looks good buds.
I wish i had the balls do do that, what other plans do u have. I think that could look awesome with right wheels, suspension, smoked indicators maybe.. i like it :D
lol,
In the next few weeks, ill most likely be going gloss black Rota GTR's 18x?? (undecided yet)
Smoked indicators all around are already on the way from japland.
And then possibly a new kit depending on funds at the time.
My taxi, completely stock:
Damn that thing is high!! Slam it to the weeds :thumbsup:
Done, about time too!
Apologies for the photo quality, we've been a bit short of sunlight recently...
Cheers
Edited by V28VX37
Looks good buds.
Damo_R34 has same offset and rims as me but in black. Only problem he had was the rear guard making 'gentle love' to the tyres over bumpy roads.. perhaps his car is sitting lower then mine
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
