It is that :)
Thats what the wheels were designed to look like :)
ahh now i see.
i always thought the centrelock LMGT's were just centre caps of sorts.
didnt know they were limited edition
Edited by alex182
You know you wanna put some on your car Matt..
Yeah mate. Then for the front guards and to swap the Nismo front bar for a Z one... much as I don't like the idea of changing body panels it is tempting. Bonnet is already changed.
[puts hand to chin]...
If you do this Matt, I will gladly take your nismo front bumper off your hands if you wanted to move it on!
It would be terrific Chris if you could research what R&D went into that paint!
Sure it's supposed to be a 4-layer paint - and sure, the base coat is ultra important; but this paint is so superior to similar colours put out in Mazda 3/6 and Falcons.
Maybe the local panelbeater has the answer?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
