Awesome work guys! Love coming in here and checking out the pics!
We have a decent cruise on the 21st with 8-10 R34's attending, will hopefully get the boys to do some group shots :yes:
More details mate, is there a thread for this?
looks like a fair amount of work has been done under the hood... quick specs?
ah ok.... lil run down list is far too long lol
tomei poncams
arp head bolt set up
full race engineered head block by JHH engineering (port polish the whole 9 yards)
wiseco forgiez
forged bottom end
hks t04s turbo
arc cold air intake box
greddy intake plenum
rc 810cc engineering injectors - fuel rail
sard 52mm (i think ) external wastegate
top mount mani
greddy radiator & intercooler
hypertune 90mm throttle boddy
saard fuel pressure reg
arc surge tank wallbro fuel pump
everything exhaust, mani , intake ceramic coated
full Apexi el2 gauges oil pressure,temp , water temp boost control unit
Apexi avcr & rsm
vi-pec ecu
Os Giken twin plate clutch
fly wheel machined and lightened
2 way differential
slotted brake rotors front and rear
endless break pads
upgrade prop shaft balanced etc
hks ssq
Thats a quik run down list is a stack of a4 pages of receipts lol
Basicly have built this as tough as money can build a 25 det without stroking.
yea 'MONEY PIT' would prob be the words I would use.... but love it so much . 18000kms on clock parts done just over 6000k's now.
If your in queensland and going on the Charity run on the 4th of Nov im heading there so if you are wanting a nosey to perhaps get some tips on upgrades more then happy to unload the knowledge learnt so far.
Running 400bhp everyday tune 548 on second tune.
car has been built for 1000hp but still need to upgrade turbo, intercooler and modify fuel set up to run it.
Will definately be at power cruise 2013 with these figures running.
Anything else you may want to know pm me or post up here.
Cheers
Looks good mate, does this have a ridiculous list of mods and was for sale in the past few months????
Thanks Mate.
Na was never advertised i dont think, But Yeah i have owned it for about 4 weeks now. Bought it in canberra of a mates cousin. Has a crap load of work done to it with Nitto 2.7 stroker. Goes in on monday for a tune, should make around the 650 to 700 mark i am hoping, but we will see what happens. Motor is built for around 700kw so i was told by the guys that built it.
Edited by Sonny1986
That sounds insane man, well done. Unfortunately I'm far from Brisbane, but you should head down to Goulbourn for SAU Nationals in November coz it's going to be HUGE :thumbsup:
Yea man definately good potential to come out of it but like we all know time and money, then more money .....
Definately was considering heading to Sau Nats but changing country and car and more work financially cant make it..
Got a Uras front lip ages ago & finally got it on the car as well as a set of 18x9 Enkei RP02's.
ive been looking at one of the uras lips for my gtt of recent, just wondering does it smooth back in in front of the wheels or stay flared out.
cheers
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
