What are the quality of their products like? i bought a carbon 'jun' front lip for my 33 gtr from asia, and it was stepped on during shipping and cracked really badly.. had it repaired but couldnt be repaired back to 100%.... just noticed these guys do them as well.. thinking of getting them to make me one how have you found their products :)?
Cheers.
well thats no good. the product is really good. had to drill a few holes to mount it but it held up very well. its very strong. looks good. i'm very happy with it.
Pretty happy with how my plastidip turned out :rolleyes:
Finally got my coilovers in and no I can't go any lower as it already scrapes getting in & out of my driveway lol :action-smiley-069:
Looks cleans, been looking to platidip for my wheels just not sure yet.. How much it end up setting you back and did you ebay it?
Thanks, yeah got it off Ebay from a guy in Melbourne, 4 cans cost around $100 including postage etc.
It's really easy to apply & you can simply peal it off if you arent happy with it :thumbsup:
Did you use all the 4 can or only needed half?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
