What profile tyres? I had dramas when I had the same size wheels with 275/35, changed to 30 profile and was all good.. Although mine is not as low as yours..
I had 30 profile because I knew that a 35 profile had changed the overall rolling diameter especially for 285/295's.
For eg a 285/35/19 for 10.5 wide rim is 682.1mm whereas mine now is 647.6mm. Essentially, a 18x10.5 rim should manage a 300mm wide tyre with lowest profile possible at an offset of +15
This is because I didn't want to roll my guards or cut anything inside my guard either and the fact that I want to at least manage 90% of a full lock with no rub too.
Also have a look at the blue and white pic together and what seems to look like the same front bar the white one has these two bumps/fangs below the gtr badge. Is it only the original ones that have that and the ones without are fake?
Hey Dim as others have said, the front bars with the 2 'Nissan' style bumps in the front grille are replicas. The original GTR front bar from Nissan has these, though both the Nismo Ver.1 and Nismo Z-tune front bars do not have these. Some replicas (or most actually) of the Nismo Z-tune front bar don't have those bumps and are therefore 'identical' replicas, though others such as those from Bodyform Aero do have those bumps. I know for fact that the entire kit on the KSR GTR was made by Peter at Bodyform Aero. Props to him and his top notch work! - I think with the 2 bumps in the grille it is a more individual look and is a good combination of elements from the standard Nissan bar and the more aggressive styling from the the Nismo Z-tune bar.
ok yeah i see what you mean.. still confuses me a bit lol With 18's like yours ive seen is the perfect size and fitment. Ive spoken to a lot of other guys that are running 19 and there all 10.5+22 and look great, where all the guys running 19's.. +12 are having scrubbing issues.
Also, I run 19 x 10 + 20 with no scrub on full lock and I'm using 275/30R19s. I did however get a bit of touching when I had 275/35s on - my car was sitting quite low before however but once i jacked it up a bit and swapped the tyres I had/have no issues at all (it's now just sitting on 10cm from the ground). In terms of worse handling you're right. It isn't that bad for street use (you've sat in my car so you'd know!!) but its definitely rougher than 18s with more rubber. I regret selling my 18s because now I need another set (this time wider) for the track.
Also on this note, it is one of my PET PEEVES seeing for sale ads for R34 GTRs where the owner advertises a 'full z-tune bodykit' just because they have a set of Nismo/replica side skirts and rear pods!! WHAT ABOUT THE FRONT BAR, GUARDS AND HOOD?!?! How are those skirts/pods specific to the z-tune and how does only having those make it a '"full kit"??!? Some GTR owners know very little about GTRs.....
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
