What profile tyres? I had dramas when I had the same size wheels with 275/35, changed to 30 profile and was all good.. Although mine is not as low as yours..
I had 30 profile because I knew that a 35 profile had changed the overall rolling diameter especially for 285/295's.
For eg a 285/35/19 for 10.5 wide rim is 682.1mm whereas mine now is 647.6mm. Essentially, a 18x10.5 rim should manage a 300mm wide tyre with lowest profile possible at an offset of +15
This is because I didn't want to roll my guards or cut anything inside my guard either and the fact that I want to at least manage 90% of a full lock with no rub too.
Also have a look at the blue and white pic together and what seems to look like the same front bar the white one has these two bumps/fangs below the gtr badge. Is it only the original ones that have that and the ones without are fake?
Hey Dim as others have said, the front bars with the 2 'Nissan' style bumps in the front grille are replicas. The original GTR front bar from Nissan has these, though both the Nismo Ver.1 and Nismo Z-tune front bars do not have these. Some replicas (or most actually) of the Nismo Z-tune front bar don't have those bumps and are therefore 'identical' replicas, though others such as those from Bodyform Aero do have those bumps. I know for fact that the entire kit on the KSR GTR was made by Peter at Bodyform Aero. Props to him and his top notch work! - I think with the 2 bumps in the grille it is a more individual look and is a good combination of elements from the standard Nissan bar and the more aggressive styling from the the Nismo Z-tune bar.
ok yeah i see what you mean.. still confuses me a bit lol With 18's like yours ive seen is the perfect size and fitment. Ive spoken to a lot of other guys that are running 19 and there all 10.5+22 and look great, where all the guys running 19's.. +12 are having scrubbing issues.
Also, I run 19 x 10 + 20 with no scrub on full lock and I'm using 275/30R19s. I did however get a bit of touching when I had 275/35s on - my car was sitting quite low before however but once i jacked it up a bit and swapped the tyres I had/have no issues at all (it's now just sitting on 10cm from the ground). In terms of worse handling you're right. It isn't that bad for street use (you've sat in my car so you'd know!!) but its definitely rougher than 18s with more rubber. I regret selling my 18s because now I need another set (this time wider) for the track.
Also on this note, it is one of my PET PEEVES seeing for sale ads for R34 GTRs where the owner advertises a 'full z-tune bodykit' just because they have a set of Nismo/replica side skirts and rear pods!! WHAT ABOUT THE FRONT BAR, GUARDS AND HOOD?!?! How are those skirts/pods specific to the z-tune and how does only having those make it a '"full kit"??!? Some GTR owners know very little about GTRs.....
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
