Steve, you want the ztune side skirts?
Si, i've got a pair, but what i've realized is that they don't fit up under the GTT body correctly, there doesn't seem to be any suitable mounting points.
Thinking of getting a set of skirts through viva garage that basically replicate the side skirt of a gtr and also have the nismo skirt moulded into it.
I have the same dilemma, have the GTT pods but need the skirts to complete the look. These are simple add ons for GTT but the full skirt fills the car out a lot more.
I'm liking the subtle differences like the pods and tinter rear indicators (and ofc the colour), looks like a completely different car to what I saw at the charity cruise. gw
Edited by sonnyQ
I always say i am against body kits and big wings etc but to be fair, that does look pretty good! Mine is just plain jane! Nothing flash....
Yep i have those,
They don't bolt up correctly under a GTT, i got my rear pods from them also (well actually purchased through a third party which was probably a mistake but anyway the pods are fine to bolt up, rather than using self tappers like they provide i drilled 3 holes in the plastic rear bar and used a nut and bolt combo so they can be easily removed and refitted if need be.
I now plan to purchase THESE side skirts which as you can see replicate the gtr skirt with the nismo lip moulded in.
Also have the top secret style front bar that JSAi has for sale with the gtr front lip.
I've managed to get it to fit pretty flush where it mates up to the front quarter panels, but it sags a little under each headlight, not over joyed about that so i'll be attempting to make some for of bracket to pull it up under the headlight. Thing is im trying to do it in such a way that it has ease of removal for when i need to drop the front bar for whatever reason.
Edited by RusH_
Yeah the viva garage ones look like the best option.
What does JSAI recommend for fitment of the skirt add ons? Might be keen to take them off your hands if you don't want them...
Yep i have those,
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
