Hey Shaun, saw you today at the MSCC meet.
Recognised the car from SAU, didn't get a chance to have a chat but got some half decent shots of your car.
One of the best 34R's in Melbourne, definitely!
Nice photos, thanks.
It was a great day today. Dad and I drove down there together, Dad was in his 67 Mustang.
Was a good variety of cars on display too.
I think I need to give my car the Z-Tune treatment....
The choice between S-Tune and Z-Tune is hard, but I am actually tempted to go S-Tune.....there is just so many Z-Tunes getting around now.
Wow ... those police cars look hot!
Jokes, awesome GTR's.
Great shot by Chris :)
Also looking good Corey.
White with black rims haha
I would feel like I am copying old mate Mat
White is super easy to keep clean..Black always looks dirty
black isn't always dirty, it gets dirty quicker, there's a small difference!
oh and here's a nice idea for you: white gtt, black rims, but make the wing stands black, while keeping the wing white. I see this unique feature on a GTT in my area, but i don't think he's on SAU. looks real nice and it really threw me off the first time i saw it, i knew something was 'wrong'!
Is yours black Chris?
Post up a photo :)
So you mean you just want to go Nismo front bar...
Rather then Nismo Z-Tune front bar and Nismo Z-Tune guards?
Yeah, correct.
My two options would be either the...
R-Tune set up (essentially an S-Tune with additional of R-Tune bonnet and R-Tune rear over fenders)
Z-Tune set up (essentially an R-Tune with newer Z-Tune front bar and Z-Tune lower lip)
The only challenge with the Z-Tune is the lower lip is super expensive and I have not seen any replica versions out their.
The good thing with the R-Tune set up is I can do everything except the bonnet to start with and it will still look authentic as an S-Tune, then once the bonnet goes on it becomes authentic to the R-Tune.
Z-TUNE SET UP
http://www.nismo.co.jp/en/products/competition/ie/r34aero.html
- Z-Tune Front Bar
- Z-Tune Lower Lip
- Z-Tune Front Guards
- R-Tune Bonnet
- S-Tune Side Skirts (already have)
- S-Tune Rear Pods (already have)
- R-Tune Rear over fenders (already have)
R-TUNE SET UP
- S-Tune Front Bar
- R-Tune Bonnet
E697A5E794A32FE382B9E382ABE382A4E383A9E3
m_111230c.jpg?c=a1
Its not a GTT or GTR :blush: nor the greatest photography lol... but its mine :)
Corey is that a full Impul kit (and is it genuine?) it looks awesome!!! Would love to take it off you....i mean your car.
Post up a photo :)
Yes! It's up a few pages back. But here are a few very slick black 34s, mine is there too https://www.facebook.com/media/set/?set=a.187686114613131.42022.104396516275425&type=1
Yeah, correct.
Z-TUNE SET UP
- Z-Tune Front Bar
- Z-Tune Lower Lip
- R-Tune Bonnet
R-TUNE SET UP
- S-Tune Front Bar
- R-Tune Bonnet
m_111230c.jpg?c=a1
Ah yeah, I see!
I just love the Z-Tune front guards as it makes it more aggressive with the side vents.
Either way, both are good :D
Yeah, correct.
Z-TUNE SET UP
- Z-Tune Front Bar
- Z-Tune Lower Lip
- R-Tune Bonnet
R-TUNE SET UP
- S-Tune Front Bar
- R-Tune Bonnet
m_111230c.jpg?c=a1
Go S/R tune kit over Z tune IMO.
