Ben,
I have the same LM GT4 (19/10.5 +15).
How did you manage to get your rear wheels to sit so far in/under the guard. My rear rims stick out a lot more than yours.
And I think you mentioned your tyres are 285 wide. What brand are they?
Thanks
MIchael
Hey Mic, now you've got me stumped, as they just bolt on mine! Tyres are Nankangs. Pics of yours mate? I'm interested to work this out.
I need to meet someone with a decent camera! lol Here's mine, snapped with a 2 meg Nokia :laugh:
Nice C-West body kit!
Nismo LMGT4's looks GREAT!
You need a better offset in the rear tho.
More of a Negative offset to fill out your rear guards.
IMO :D
Here's the pic Benny
I'll snap a pic of mine on flat ground in the garage this afternoon. I'll also grab a straight edge try and gauge some measurements re gaurd clearence with that.
It's also worth noting I run close to 3 degrees of neg in the rear.
Edited by Marlin
IMO :D
Thanks mate :laugh: These genuine kits are so nicely made! I was astounded to see the quality compared to our home grown copy stuff.
Without much camber in the rear, the wheel is actually nearly level with the gaurd, but as I've now got about 3 degrees on it, it moves the upper wheel in a little. I small spacer would be sufficient if it bothered me, as I'm not going to order new wheels, they're kind of expensive. I'm led to believe these are also the only offset that Rays make them in 19x10.5. :D
Thanks mate :P These genuine kits are so nicely made! I was astounded to see the quality compared to our home grown copy stuff.
Without much camber in the rear, the wheel is actually nearly level with the gaurd, but as I've now got about 3 degrees on it, it moves the upper wheel in a little. I small spacer would be sufficient if it bothered me, as I'm not going to order new wheels, they're kind of expensive. I'm led to believe these are also the only offset that Rays make them in 19x10.5. :(
If I were to go a full body kit on a R34 GTR, C-West would be the one, with the Version 3 Front Bar. which I think it what you got.
Can't say I am a fan of the silver mesh though...
Or Nismo Z-Tune Front guards and Nismo Body kit is another I would go for.
Ah yes, spacers will help! +1 for that.
I too have a (from memory) 5mm spacer in my rears, just give it that extra fill out.
What offset is your wheels?
Is that the Yokohama ADVAN R34 GTR in the last pic?
As in the Hi Octane Racing one?
That car is Friggin awesome!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
