  • Replies 101
Hoorah! Hoorah! Hoorah for speedy organisation *takes a bow* ;)
Andrew & I will be there from 6. We are going to arrive early to make sure we can get enough tables, push them all together, and then we're going to have a couple drinkies while we wait upon everyone elses' arrival :huh:
We might come up early Anna have some drinks with you 2... :P
mmm texas bbq pizza and beer battered fries was good, sorry me and carolyn couldn't stay for ice cream but still had fun, lots of ppl turned up! :laugh:
oh and big upz to chris for bringing in the crispy cremes :)
Good night guys, great to have some good car discussion at the end there. I'm always keen to learn who knows what and learn anything related to lines in general.
I'm trying to make sure I remember all your names, so if I slip on your name please don't feel bad as I have done my best.
Though the guy I was talking to with Mel at the end there, I never caught your name. Let me know, because you were a great help :)
Cheers guys,
Ben
Ta, Sorry Troy, but you were the one person I just spoke to without asking a name. Doh!
I was late to work in the morning..... more due to the fact I'd never been to this other place for training and road works had the city all weird... I got lost for an hour... ha... crap :ninja:
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
