most of the tinters will do it for you . you just have to ask for the good stuff 20%..... they will warn you about the legalities etc etc...
Its never really a problem until RWC time
Edited by ish
https://www.sau.com.au/forums/topic/147451-window-tints/#findComment-2752167
yeah most tinters will do it for you, they will always warn u about the legality issues and most of the time make you sign a form stating u know very well its illegal and its your own fault if you get caught :devil:
go for it, i had 7% on one of my cars, now that was sexy
https://www.sau.com.au/forums/topic/147451-window-tints/#findComment-2752433
Yeah, a lot will but warn about safety & RWC issues.
Some will not receipt the work.
My tinter had 5% on a black 4WD with 30% on windscreen.
More for promo work, but he reckons he could down a tinny at the lights next to the cops & they couldn't see in. :0)
https://www.sau.com.au/forums/topic/147451-window-tints/#findComment-2753052
i have 5% on my car got it done about a month ago. Most tinting places will do whatever percentage you want you usually just have to pay them in cash though. just call any of them out of the yellow pages and ask for the % you want. I had 20%'s on my celica which i got done at tint a car, my 5%'s on my 33 were done by guys called southern cross window tinting.
https://www.sau.com.au/forums/topic/147451-window-tints/#findComment-2762466
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
