  • Replies 220
The manual and PFC solved some issues then . Did you do any thing with diff ratios or are they ok ?
A/R I wouldn't like to guess because its not my money involved if you don't like the result . Its the same situation with RB25 Hi Flows and RB25 vs VG30 exhaust housings .
Latest info to hand , will use same cartridge as HKS version.
Cheers A .
I managed to find out the final spec of this GT3076R 52 trim turbo . It will use the same cartridge as HKS's 52 trim GT3037 and GT3037S so CHRA number 700177-5006 . It will have a port shrouded TO4E .60 A/R compressor housing and one of Garretts integral (internal) waste gate turbine (exhaust) housings .
The ask is going to be ~ 2G which while not chicken feed is not too bad considering you get the ported shroud comp housing , a propper integral waste gate turbine housing with T3 flange , and the waste gate actuator and mounting bracket . The closest thing would be a HKS GT3037 Pro S which would be considerably more expensive and only available with the 56 trim compressor wheel .
I dug up some power (potential power) figures from HKS and they quote 450PS for the GT3037S 52T . Interestingly the slightly different "S" varaint gains 10PS from its port shrouded compressor housing which is the main difference . So if PS is approximately the same as Hp then Kw potential equates to 337 . I would have thought a bit over 400 and 300 but I'm conservative .
One unknown at this stage is will this unit require a spacer plate between the std RB20/RB25 exhaust manifold so that the compressor housing clears the manifold casting . If anyone has a "real" GT3076R with the Garrett IW exhaust housing on the std exhaust manifold can they let us know if it fits with or without the spacer .
Brett at GCG expects to have these turbos here in March 07 . BTW they have available now an exhaust housing thats dimensionally the same as Nissan RB20/25 in .70 A/R for those that want a bolt on style housing for some of Garretts GT BB turbos .
Cheers all , A
Edited by discopotato03
How much would it be for them to convert one of these turbo's to an external wastegate housing.
Reason I'm asking is I have the HKS cast manifold and my options are to plate over the wastegate mount [block it off] or convert the turbo to external. I reckon the plate over the wastegate mount is cheaper, but then I'm not too sure what this would do to my airflow?
DP3 I'm definitely interested though, could be the exact turbo for the RB25. The numbers and specs place it somewhere between the 2835proS and the GT3076, so good performance right in the sweet spot for a road car, minimal lag, adequate top end.
The go would be to buy the turbo with the external type GT30 exhaust housing if you are already running a manifold mounted ext gate . I did ask Brett about the non gated housing option and I doubt it would be a problem for him to fit one but he's the one to ask . Bolting a plate to the manifold is not difficult to do if you go for an integral waste gate .
Integral gates are never going to be as simple as externals because of all the bits attached to the turbo make things fiddly in crowded places . I just have my doubts about getting away with externals if the cops go looking for non std bits . With a bit of effort the integral can be made to work and not look too life threatening . The trick is to make everything look as OEM as possible .
Size wise yes the GT3076R 52T fits just over half way between the GT2835 Pro S and the GT3076R/GT3037S 56 trim . A bit more turbine flow than the first and a bit less compressor load than the second . It certainly has the makings for a good 2L four or 2.5+ L six , IMO anyway .
Cheers A .
Rather not do that, just a plate and gasket would do. That way I can still use the mount if I ever want to. Weld is a bit like..permanent...lol.
Plus weld on cast would be more prone to cracking with use. You'd have to have the plate made out of similar material otherwise you'd have different expansion/contraction rates between the plate and the manifold. With a plate and gasket there should be sufficient 'slop' to allow for expansion/contraction.
yeah lol there is that. I'm pretty sure if i bought a nice new turbo i wouldn't really want to start welding shit on it straight away!
No, I wouldn't weld/plate the turbo. I intend to plate the manifold!! The turbo will be untouched.
yeah i know. I was saying that regarding my suggestion before...
Edit: wait i think u may have mistaken what i was saying, i wasn't saying to weld up the External wastegate port on the manifold, i was talking about welding the internal wastegate on the turbo...
should be easy enough to get and external gate housing but what we really want is someone to buy and internal gate version and give us the good oil on outputs and response....so we can bludge off the knowledge.
One unknown at this stage is will this unit require a spacer plate betwewen the std RB20/RB25 exhaust manifold so that the compressor housing clears the manifold casting . If anyone has a "real" GT3076R with the Garrett IW exhaust housing on the std exhaust manifold can they let us know if it fits with or without the spacer .
I needed one for my real GT3076R with T3/T4 style turbine housing, which I assume the GT30-IW turbine housing would probably be based off the general style of.
I'd be very interested to hear how these go. I find it interesting that Garrett list their 52-trim GT37 as having an 82mm exducer.
That is because a "GT37" turbo is a GT37 turbine based turbo whereas a GT3076R/GT3037 is a GT30 turbine based turbo . Yes the GT37 turbos have either GT37 or GT40 series compressors ie 76.2mm or 82mm .
Try not to confuse turbine and compressor families , a "GT30" turbo does not have a GT30 compressor though a GT37 turbine based turbo can have a GT37 series compressor and is nowdays called a GT3776 . The 82mm compressor version is called a GT3782 .
If a GT30 turbine based turbo has an 82mm compressor its known as a GT3082R or a GT3040R because smaller series GT40 compressors are 82mm OD .
The one I mentioned has a GT30 turbine and the 76.2mm GT37 series compressor , Garrett call it GT3076R and HKS call it GT3037 . If they really wanted to get it right they would say 60mm 84T GT30 UHP turbine/52 trim 76.2mm BCI-18C compressor - bit of a mouthfull .
Cheers A .
Ahh ok - I understand the turbine and compressor families, though evidently made an incorrect assumption when I was reading a compressor map that had overlays of different GT37s - I assumed that a compressor map which was titled GT37 would be for the different trim variations of the GT37 compressor wheel.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
