to my understanding when a bearing pack in a turbo fails you get shaft movement from the ball bearings breaking down which can cause the turbine/s to hit the housing wall giving you a whirring sound.
can the bearing pack also "pack up" or basically clog up and also cause this sound without the turbine/s coming into contact with anything...?
had 2 seperate stories from the turbo rebuilder and it just isnt adding up at the moment so i thought id ask for any experiences that other people have had.
thanks
Iz.
https://www.sau.com.au/forums/topic/147942-failed-turbo-question/
eg:
Blocked oil feed to turbo,
Turbo with no oil on bearings = to much heat/friction = The same thing that happens to every bearing that requires oil or a form of lubericant = noisy and broken
If the bearing is completly fruguled and bits are gone = bad shaft play and wheel says hello to housing.
Sounds like you need a new turbo :P
eg:
Sounds like you need a new turbo :yes:
problem is i have had a new bearing pack twice in 4 weeks.... and the sound is starting to appear again after 1 week.
definately not an oil feed problem, its a new line and i tested the bejesus out of it before connecting the oil drain up to the block a firing.
anyways im not here to winge, just to find out if u can get shaft play on a new bearing pack after 1 week....
time for bearing pack number 3 i guess.
just had a thought..
could there be a difference in the oil feed line fitting as it was a hks turbo but they fitted a garrett bearing pack, i know garrett make hks but just wondering if there may be a difference in the volume of feed to the bearings.. ie diameter of the nipple.
this is really causing me grief now and everyone is closing down for the holidays...
Logic would tell me,
what is your oil pressure like? oil pump working properly?
also, I agree about the "difference in the volume of feed to the bearings.. ie diameter of the nipple."
the lines that you get from HKS for the turbo are different to stock ones, I suppose they are slightly larger, have a look, at some, and take it from there.
well pressure wise it "seems" ok... if going by the gauge on the cluster is a good reference. sits on 4 most of the time. oil was flowing out of the drain line after 2x 10 second goes at cranking the engine over. can pressure drop during driving? im talking around the block driving no track work high rpm stuff.
id like to look more into how the oil pump works and creates pressure up into the feed line if anyone can point me the right way to some pics or documents/manuals.
thanks.
As it appears that your turbo needs to be rebuilt again, ask the reconditioner if it has signs of oil starvation, the bearings will probably be discoloured. I would remove your oil pump, as it is the most likely cause, and they are problematic in rb's, also chech the pressure releif valve(in the pump. The only other thing you could try is removing the oil filter housing as well, and cleaning out the passage between the pump and oil filter and the filter and the turbo. While the sump is off(to remove the pump, check the oil pickup for clogging or cracks/looseness.
You'll easily tell if its oil, there will be "burn" scored all around the cartridge etc.
Usually a blue-ish colour.
If you see that, or the turbo shop says thats what it is, then it cant be anything else than low pressure of blocked lines
the original bearings had this blue colour!
what made me sceptical was first rebuild they gave me all the old parts back..... second time around they accidently thru them out.
in the end bearing noise is bearing noise and can only be caused by oil starvation from what i gather, the whole turbine theory and 3 fauly bearing packs theory is out the window now.. :)
i just want to make sure all bases are covered this time around. will give the oil pump a crack over the weekend and see what i find..
is it a good idea to pull oil cooler, cooler lines and filter relocation lines off and go thru the lot?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
