Originally posted by doxximus
bring me back those piss beer guys who piss in the snow on comedy channel beer commercial please i need some signwriting done
the ones that sign their name in the snow??
that aint beer thats CC (canadian club) which is the best whiskey in the entire worls with dry ginger ale.
mmmmmmmmmm CC & Dry
https://www.sau.com.au/forums/topic/14827-the-20th-of-may/#findComment-301087
no way! Japan is the best country in the world!
i would partially agree with this, japan is the best place ive been out of the whole trip, and im currently learning some of the basics so hopefully i can impress some of the hotties there.
i trust u will be getting a line again???
i never sold mine its still at home its been driven regulary and kept in a lock up garage. It needs me to spend some money on it :(
and as for the rest of you, you are all greedy bastards. maybe i should try to bring home a girl from japan.......:):):):):)
https://www.sau.com.au/forums/topic/14827-the-20th-of-may/#findComment-301090
