  • Replies 6k
Posted Images
Thats 'cause we're always at the Drags trashing our cars.Was a fun day today - I did one run in the EVO - 13.4 @ 105mph. Not too bad for a stocky.I also took big Paul's black R34 GTR for a burn
& managed a clutch slipping 13.1 @ 106. Also not bad for a total stocky.He's getting a new intercooler at Tilbrooks tomorrow so I think he'll be back for more.I missed Matts new car run but I heard it ran a 1*.** @ *** mph - very impressive.I'll do the same as Pauley & let Matt tell everyone himself.
See you on the street. Laters.
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
