  • Replies 6k
Posted Images
ah ok cause there is this guy a trader here on SAU has a xls spreadsheet to workout how much item will cost to get to australia
http://www.slidewizeimports.com/
Luke you so goto take that up if you got the reddies its a once in a lifetime opportunity GT4 with RB26det or tt
and dont worry about your drive train its the same as GTR spec just they cut cost by no brembo and no RB26dett thats why GT4 so much cheaper
Edited by Madaz
cheers mate. still deciding weather or not to get it. since theres lots of parts missing off it, would be pretty crazy tho.
unless i just get it and slowly build it up, big turbos something that people wouldnt know what has hit them.
decisions decisions
might give this one a miss. looking at it now theres to many this missing. like no loom, turbo's, alternator, throttle body opener thing. would probably end up costing around 11k to have it all going.
but dont worry i will still be looking for one.
ITS OFFICIAL I HATE AFL. All the damn port supporters have booked all the flights and accomodation in melbourne for the weekend so i may have to miss out on he Intermarque round :whistling:. Its a pitty at last count there were 32 exotic supercars entered
awww will have to come on my lousy cruise then Nick :whistling:
I could go QANTAS but they want over $700 each way!!!! no wonder why i always fly virginblue you can fly to Melbourne and stay a few days for the price of one flight
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
