Thought i could start a bit of chatter going about with things people are wanting to do to their cars, and if people wanted to chip in with tips or places to get things done, that would be sweet too.
Basically i want to get a few things done this year to her. In somewhat rough order of preference/requiredness here goes.
1. Fix that darned Exhaust leak - Its post turbo (not losing any boost) and its basically put a swarm of bee's in the induction sound, depending on the load/speed you're doing, it can sound anything from god dawned awful (idle) to pretty mean (we wont talk about how fast we're going). (Planned for when it gets her 80,000km service next week).
2. Rebush the whole car / sort its suspension out - pretty much all the rear subframe is shot, i have a slightly woofed lower control arm and the bushes up the front aren't all that pretty either. Problem is its ~$600 worth of bushes, ~$200 of lower control arm and about a day's work (according to Mark at Belco) to shove it all in and make it sit pretty again. The car is drivable, handles ok, but the inside of the rear tyres seem to be wearing somewhat quick (2 deg neg camber O.O). (Late Jan -> Feb)
3. Ditch the Pod, get a good cold air box - i like the suck, i really do, but it DOES get irritating after the 4th or 5th hour on the hume hwy to Melbourne. (Late Jan -> Feb)
4. A Bigger Turbo. I'm 194kw at the wheels, i want more - probably 260-280. And i want to really really feel like we're going places when you drop 2 gears for that Highway overtake. The PFC, FMIC, Fuel Pump etc are all there, just need a bit more ooomph. (Haha, when we get there - Tax Cheque maybe?)
So there is my list - what is everyone else out there dreaming/wanting?
Edited by nsanity
https://www.sau.com.au/forums/topic/148761-new-years-resolutions-for-your-car/
I'd like to get mine resprayed mainly, but I doubt that's going to happen :nyaanyaa:
Power's fine for the moment, though something like an AFC Neo wouldn't go astray.
Other than that, nothing really, got bigger fish to fry
I think I mentioned it b4, This year like insanity Id like to get the suss pension done (SK) and some decent rotors and pads.
Some mates to help me out with Tyre$ and a great detailing job for a few slabs..... Now who volunteerd :nyaanyaa: I remember, will PM when ready.
Bigger turbo 3037 but a garrett, attach it to my HKS cast manifold, intake and dump. Aim for 300 but settle for 270.
And I'm not selling unlike some of you other wishy washy types........lol, I'll enjoy the import scene while its going, even if it is in its twilight years.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
