Well with my Green Ps soon to expire I thought it would be a good time to sit for my full liscence... so I've booked myself in for 9am tomorrow morning (gotta squeeze it into 2006).
Also just spent the last hour reading all 94 pages of that hand book - pretty self explanatory stuff (apart from the emphasis on statistics). Did all the online tests and passed...
Questions:
1) Should this be sufficient preparation?
2) How much emphasis is there on the stats in the actual test?
3) Is the DQT a lot harder than say the Greens?
4) What's the best option after you pass; 1yr or 3yrs :O
Thanks + wish me luck for tomorrow :P
S
>_<:laugh:
https://www.sau.com.au/forums/topic/149056-going-for-fulls-dqt-rta-nsw/
Yes, unfortunately for us younger generation the RTA has turned the liscencing system into some money laundering scam... there's a total of 4 tests now (each with associated costs) before you can call yourself a "liscenced driver"
Thanks, will get the 3yr if I pass >_<
from memory the final full licence test is not that hard. they do the usual trick of asking a few misleading questions, but you are allowed a couple of mistakes so dont sweat it too much. just keep reading that book right up to the time you go in for the test. >_<
yeah, if you have good driving history they will let you get the 5 year gold licence. get it if it's available to you as: 1. it's cheaper, and 2. you'll get to have the same picture for 5 years. so when your 30 you'll have a pic of yourself at 25. though that may be a negative and just make you feel old.
You'd need a crystal clean history then right?
I've only ever been picked up once and that was for a stop sign - you think this will be "good" enough?
You don't have to be perfect to get a gold license. I got mine when I had 4 demerits.
You just have to hold a full license 5 years without a suspension.
Ok stanny boy, I am the guru on the test. If you want, give me a buzz with any questions, and i'll explain it all to you. I've pmed you my number.
But basically, the knowledge test isn't your usual road rules. They exmaine you on statistics. e.g. being a bogan makes you x times more likely to crash. Drinking while getting a blow job is x times more likely to crash.
for the other part, it's scenario based where you touch the screen. There is a catch. you have to touch the screen more than once, unlike the green p test which you only have to touch once. there is a special technique to this one.
for more info, give us a buzz.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
