Hi ppl,
I went from 2nd gear to 3rd gear, then tried to go to 4th but no go, the shift wont move in any direction. There is no grinding crunching or anything like that and the clutch is fine. has it grabed on the selectors? Anyone no the best way to free the gears?
cheers
Leigh
Edited by woolls
https://www.sau.com.au/forums/topic/149169-stuck-in-3rd-gear/
That's f**ked. I had my car stuck in 3rd for a while.. .it got gradually worse. Turned out to have sheared the round solid part that goes over the main axle(?) of the (SR) gearbox...
When it was stuck a few times I managed to unstick it a few times by playing with it.. i.e. not bashing but springing the pedal.. it's only going to work if it's lightly stuck. If it's well and truly gone nothing will shift it, I thought I'd bend/snap the shifter after 2 months of being desperate.
GL with it.
Well, I pulled the box apart, Found that a Part called shift insert had come out of the synchro hub. I think that came out because the shifting insert spring broke. The shift insert has done a bit of damage to the cluster, eveything else seems ok. Can get a brand new cluster for $700, A kit for $500 (main bearings seals gaskets, needle roller bearings and inner sleeves), new shift inserts $66 for 9, and the new spring inserts $6. About $1300 in total with me doing all the work.
cheers
Leigh
Edited by woolls
Thats what I like to hear...mine got stuck in 3rd...ended up costing me $900 all up including box out/in/oil, machining flywheel and fitting new clutch...so I guess I got it at an alright price....I won't mention that it took almost 3 months to be fixed though.....
Strange coincidence...mines a 98 model as well
Might of got out of it cheaper if I didn't drive about 20 clicks with it stuck.
I have been told that nissan made some changes to the box from the mid/97 to the 5/98. Mine is the 3/98 and falls into this. if it was the 5/98 or later a cluster would of cost me $440. Such as life.
Edited by woolls
Appaerently mine has some R34 internals...thats what I was told anyway, but that may have been excuses from the workshop seeing as how it took them almost 3 months to figure out what parts they needed :D
Appaerently mine has some R34 internals...thats what I was told anyway, but that may have been excuses from the workshop seeing as how it took them almost 3 months to figure out what parts they needed :glare:
From what I've found out , if your car has a build date of 5/98 or > its got what they call the series 3 box. Thats what I have been told anyway.
Yeah, dezz we'd have the same gearbox.. i've still got my main bearing stuffed and it's whining.. probably look at getting it fixed sometime..
Late R33 gearboxes are probably worth fixing rather than replacing..
Woolls, you have much trouble getting it out and pulling it apart?? Got any photo's.. def interested..
Have replaced the box with a brand new one, but I will be gathering the parts over a period of time to rebuild my old box.
They are not to hard to pull apart, (you will need a couple of gear pullers) Its just got to be pulled apart in the right stages, no bloody short cuts.
Sorry I took no pics, but when I go to rebuild it, I will take some pics and do a write up on it. (won't be for a while)
Edited by woolls
Tidy, mind if I ask what that set you back?
$3150 delivered to tassie, Retail at nissan was 4900, I could of got one off them for 4100. Just Jap sells them for 3200. But just jap and Nissan have none in Australia. I end up getting this one through a member on SAU.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
