  • Replies 54
Pro's: Keeps larger turbo motors on boost during gear change, allows you to flat shift, flames and noise from the exhaust.
Con's: fouls plugs, voids insurance (if you have any), creates excess heat in turbo system and can cause major turbo failure, illegal, flames and noise from the exhaust.
I've got one on order from homer_rulz on ns.com
Thanks for that and yes i have full insurance on my car and in NZ the rev limiter does not void it and its not illegal.
and when you say can damage turbo surely thats with excess hitting the limiter and not just daily driving
Edited by r33madd
i think you are confused, there are a few concepts to the "limiter" device and how they work
type 1
yank the throttle cable and rpm will fly to whatever you set the limiter to, so lets say 4100rpm and wont go beyond. mash the pedal / pull the cable and it wont go past 4100rpm so you have consistent rpm for launch each time
type 2
same as type #1 but when it hits the set RPM it does spark cut so you get bang bang style antilag launch. when the spark it cut, it induces misfire which spool the turbo despite no engine load so you make boost whilst the car isnt moving. so when you take off you take off at 4100rpm with 1bar boost wound up in the manifold (lets say) and the compress its on full song when you launch.
type 3
type 3 is a hybrid and lets you have 1 & 2 but also gives you spark cut when you push the clutch pedal in so you can flatshift with antilag style changes. come time to change gears, pedal in, spark cut activates, boost keeps buidling, clutch out and keep going
type 1 is just for consistent launches
type 2 will fry the exhaust wheel / cat and any parts along the way. it will shoot flames, make lots of bang bang noises, pop its ass off and generally be rally car style antilag
type 3 same as type #2
for type 2 you would want to have
- steel wheel exhaust wheel on the turbocharger
- no cat
- hiflow exhaust and big dump/front pipes
- a good safe tune and exhaust temp guage to watch the temps
type 1 - not sure, i think the bee *R does this for you
type 2 - gizmo launch interface @ www.apexi.com (under usa, electronics)
type 3 - gizmo launch interface @ www.apexi.com (under usa, electronics)
the first ill be buying when i have my evo is the gizmo box, the guys in the US/japland use these and can bring about 1.3 bar at launch
pros
will make kick ass launches
bring on boost without engine load
cons
noisey
need some precautions
not for street use
will annoy anyone nearby
need good traction to use the launch rpm / power
type 1
type 2
type 3
- no cat
pros
cons
noisey
not for street use
you are not far off, but the descriptions need a little work. basically there are 2 main types of rev limit employed in efi cars. 1. fuel cut (this is the most comon and is what your factory ecu or power FC uses). 2. ignition cut (this is what the Bee-R limiter uses, and PFC pro uses).
That is the only diference. The Bee-R device also incorporate a stationary rev limit. so when the car is not moving it will limit revs at a different point than once moving. so you can set a stationary rev limit of say 4500rpm for launch. so all you have to do is hold your foot flat on the floor and it will keep the revs at 4500 (and the resultant missfires will help build some boost too), once you have release the handbrake and started moving it will enforce your regular rev limit of say 8000rpm.
It will not allow flat shifting as it does not cut ignition on gear changes.
What you describe as type 3 is just an ignition cut style limiter and will cut ignition when the clutch pedal is depressed and cease cutting one the clutch pedal is released. this will cut power to the engine momentarily to allow you to select the next gear without lifting your foot off the throttle. I dont see it of that much benefit to be honest as you are still shifting using the clutch, and if using a synchro box you are limited in how fast you can shift by the synchros more than anything. plus when shifting at high rpm, there shouldn't be much delay in response when you get back on the gas. it would probably give a small improvement though. and the less responsive your engine/turbo package, the more benefit you would get. I'm not familiar with the gizzmo unit, but if it does what you say then this is how it would work.
I'm not sure if you will find any info on the gizzmo unit at www.apexi.com. Gizzmo is a NZ company. I think they have their own website somewhere.
yes, which is a fancy way of saying it's a stationary rev limit (executed by way of ignition cut). ;)
oh, i must be blind too. there is a whole section on gizzmo on apexi-usa. lol
its not stationary its secondary.
reason I say that is it doesnt have to be wired to the handbreak.
mine is wired to the clutch so I can flatchange gears. :)
Did not realise this, so does that mean that bee-r rev limter can also be used for flat shifting if wired to the clutch?
My sons Datto 1600 uses a Wolf with ign rev limit and a second limit for launch and flat shift and even tho it has a GT30R turbo it makes over 20PSI standing still sounding like a war zone.Been in the car a few times with Commodore drives giving him a hurry up but when he uses the launch control they gave up the idea when they hear it.
has always wonder this, which styled rev limiter is softer than the other?
i was under the impression that ignition cut puts less stress on the oil pump as well as turbine wheels.
that is true, the unburnt fuel igniting cant be doing good for zorst on the turbo.
theres arguments for and against, the main one is that a fuel cut has potential to cause a lean condition, and others argue that no fuel = no combustion, so its not possible.
Edited by midnight
Hahhahahahaha!! YES!!! thats the only reason why i want one. I just want to scare the commodores off so they settle down and leave me alone instead of giving it a hit on the street.
I wonder what boost my rb30det with gt35r will make with it standing still?
Oh and if you have the crank collar modification for the oil pump then the pump shouldnt have any issues should it ? (running stock rb25det pump)
Edited by Guilt-Toy
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
