woah! that would be big news. Very interesting. they already have ferrari engines. now they'll have schuey and brawn to help them cheat their way to the top. I like it.
and troy, I think that could be a plan. maybe we could hit up paul sotddart for use of one of his old army transport planes. there would be plenty of room for 2 cars and a few strippers too just to keep us sustained for the journey.
  • Replies 2.1k
Posted Images
"The regulation was introduced just prior to the season and the three-centimetre diameter white circle that was painted on the soft tyres for the Australian Grand Prix proved to be not visible enough."
Isn't it funny how with all the money and brains in the formula 1 industry that they could think such a stupid idea would work. First of all you have the words 'Bridgestone Potenza' printed in white on the sidewall of the tyre, now spin that tyre at 300km/h and try and workout if you can see a white dot in it all, obviously they were all on the piss when they thought of that idea.
The new idea of a white ring around the tyre is interesting and looks a little bit cool, atleast it definitely works.
I for one don't understand the purpose of the regulation requiring teams to run two different compounds. Judging by the Melbourne GP two thing can & probably will happen.
1. No one uses them until the last, shortened stint in the race because as often as not they will grain & the teams don't want to risk it. Running them on a rubbered in track lessens the chance of graining, but by then the race is almost always over anyway.
2. Cars with suspension that is harder on their tyres (mostly the mid ranked teams) just become less competitive anyway.
There is a chance the harder of the two compounds will be the better option at some tracks. In which case whether or not you run them other than last entirely depends on if you believe you will get a pace car during the race.
As ever artificial means to "spice up the racing" inevitably works for about 10 minutes until everyone cottons onto the best strategy. Then everything just reverts back to normal - wasting time, money & peoples rapidly diminishing attention spans. If they want to make the racing more interesting give everyone proper soft compound tyres & get rid of re-fuelling.
I think as bridgestone refine the differences in both compounds, we'll start to see it become a more important part of stratagy making by the teams. Because this is such a new concept the tyres are still going through some development. I think eventually it will a good specticle to watch, but so far they're still teething
Edited by ctjet
you'd think with hack teams consistently performing in practice sessions, you guys would start to realise that it means sweet f**k all in real racing terms....they're out there running times because they need to be...where as major teams could be out there raping them without lube....
Of course this is just my personal opinion on this stuff, and yes there are big teams out there in the times above....but I wouldn't be reading too much into any of it :laugh:
The 2nd qualifying session is the only way to see who is fastest in F1.
The 1st qualifying session the top teams only do enough to get into the 2nd session and the 3rd session they are on their race fuel/strategy so that can lead to different results. The race speed well who knows what strategy or tyres they are on and the same with the practice days just testing new parts, tyres, etc not going their for outright lap speed.
The only times practice sessions mean anything is when you compare them to to the lap record.
If a car can sustain a time close to that of the fatest lap for that track over long distances than you know who stands where. Anyone can piss fart around for a day than pump in a quick one at the end for the sponsors... its anout knowing the breakdown of how and when they got the PB for that session.
Ferrari and Mclaren a so far infront its rediculous
Of course this is just my personal opinion on this stuff, and yes there are big teams out there in the times above....but I wouldn't be reading too much into any of it :)
f**k you dezz.. that hurt... what about sato.. yer thats right.. sato,
Enough said.,
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
