  • Replies 2.1k
Posted Images
Or they could just fuel him slightly less so that he qualifies slightly higher (5-8 instead of 8-12) so that he has better track position in the first stint because it's easier to hold someone up behind you than it is to overtake someone doing a similar lap time.
yeah good point. but i think the problem with that he may not actually qualify better than that with the same car and setup.
team stratergy will work out. it will fall into place at some stage. Almost did in canada.
Quoted from greman newspaper and translated into english...
Sounds like a typical Joe Saward piece of bullsh!t. He basically makes up whatever he wants & reports his opinion as fact or occasionally as conjecture. More often than not he is completely wrong.
As the quote goes "Writing fiction is great, you can make up just about anything."
He is one reason why I never used to buy Motorsport News. Although now you don't have to pay for it.
It does explain to some extent whay we havent seen any sort of aero upgrades recently... Mclaren, BMW, Williams even Honda have introduced parts recently. You'd think Ferrari would be right up there pumping out aero pieces to keep up with Mclarens rate of development, but no. This week is the first week in some time that they're adding new aero parts on the car.
Just seemed like a logical explanation...
Well it's plausable. Which is the kindest thing you can say about some of his stuff.
Unfortunately for peeps like me Ferrari are dropping the ball in many areas this year and it starting to show up now the season is getting serious. I know of maybe a big aero upgrading coming but not until August which is way to late in the year. I think maybe some of those key members leaving is starting to filter through
Im with you there, typical Mclaren, more data for Dennis's mob. Calling Honda a 'B' team is a complement going on there discraceful performance this year...maybe the 'Z' team would be better.
Well it isn't actually Ron Dennis' fault. More of a case of getting a deal done whilst he cane & whilst it can benefit McLaren. The rule shouldn't have changed - each entry should be required to use a different constructor. Back in the day companies such as Lola & March supplied heaps of chassis.
& yep Honda suck wang this year. Hopefully they will improve.
Lewis Hamilton stacked his Vodafone go kart at an event today!!
ahaha, lets hope thats the only wipeout he has this year!! it was a total noob mistake! :laughing-smiley-014: :laughing-smiley-014:
check it, helmet cam style. :D:)
http://www.youtube.com/watch?v=K_4uhYoMEX0
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
