I'd like to see Kovalainen at McLaren. But I was hoping mini Piquet would get the seat, only cause of the way Piquet was mouting Hamelton during the year (or was that mini Senna?) would have been some more macca action.
  • Replies 2.1k
Posted Images
LH = soooooo yesterday....
Poor Rubinho:
:P
BTW. This is why Webbo should be in a decent car!
http://www.youtube.com/watch?v=JZpnWhM7JSE
Edited by Marco-R34GTT
This gives a fellow hope!
This is no doubt a comprehensive list...but to the best of my knowledge, once there was a guy.
Who not only had money, but a penchant for tidy women. From a whole range of supermodels, including knocking up Heidi Klum, only the dump her upon learning of the pregnancy...
To random good sorts...
To his new bride
Why wouldnt Alonso want to go back to Renault. Hell, i want a job at Renault just so that i can get close to the old boy and learn some of his tricks
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
