Thanks for the info Jared, Ill be visiting a few local performance shops tomorrow and will approach them with the theory and see what they say. So far an injector expert has given me the thumbs up with the idea and said its been done before and has worked well... so a few more oppinions before i attempt this... otherwise its Nismo 555cc's
Cheers
  • Replies 80
Ok guys, yesterday i visited a mates workshop and approached him the the "shaved injectors" idea and funny enough, he had just tried this on a customers car (S15 200sx) and this is what he found:
- Car was very hard to fine tune on top end - Haltech E11v2 (ran too rich)
- Poor Idle (rough)
He said that this mod will work better on N/A engines due to the compression... Once the S15 was fitted SARD 650cc's, the issues went away. The hypothesis was that the altered spray pattern caused poor atomisation and the different flow patterns made it harder to tune...
Cheers
- Poor Idle (rough)
Cheers
The main reason they probably have trouble that the top end is to do with the fact that there is no pressure after the injector valve once it is removed. The valve itself is not designed to have the full pressure drop across it. Having the plate there actually means there is still some pressure after the valve & also makes it easier for it to close off again.
Rough idle would have to be one of the most common complaints I had for injectors that were sent in & found to have poor spray patterns. Had many very happy customers after diagnosing that fault :).
Most pintle valve injectors close by moving out into the injector body when the solenoid is switched off so if anything fuel pressure and spring pressure are what shuts the valve . By fuel pressure I mean inside the injector body itself . Any restriction downstream of it would cause a pressure rise between the multi hole plate and the injector valve itself though this is unlikley to help it close .
If I was going to do this I'd experiment with the pink top Pulsar N15 GA16DE injector because shaved they are supposed to give somewhere in the mid 400's cc flow rate . When you start to get into 500 + cc injectors for 4-500 cc cylinders the computer has to be capable of controlling them at low engine speeds , it has to be able to open and close them very quickly and time the injector close stage accurately . The tuner has to have a good handle on the whole sequential injection process with aftermarket ECU's because there's a lot more to it than just spray it in and fire the spark plug , some of the Haltech people had little interest in sequential injection prefering batch fire which is a bit crude in this day and age . I know everyone says PFC's are good at accurate large injector control so they must have good injector drivers to do it well .
BTW the shaved injector was always going to be a cheap option and possibly the only one available for some people . Its very possible that the aftermarket has found ways to gut the injector and surface the seat area of the injector body and valve to help get better spray patterns , we need someone on the inside to tell the story here .
Cheers A .
Well from what i have found out, this mod does work however tuning will be harder as well as idle quality will suffer... im leaning toward a highflow set of 555cc from Deatschwerks or 550cc Nismo's...
cheers
Edited by QRI05E
  • 1 month later...
I know of a workshop in Melbourne that highflows RB25 injectors. They actually have the parts so when they shave them the refit new caps to give the right feed rate, then the flow test them so you can balance the injector pulses. They do charge about 70 each including the parts needed, clean and flow test so not a bad option there either.
Nice find though disco.
By any chance do you know what the workshop is called? I'm in the market for injectors at the moment...
yeah very interesting thread, my foreman told me about this as they've been doing it to WRX's for ages but they were using a CNC machine to open up the holes in the pintle cap. they said the hardest thing was getting the flow rates the same but using the CNC made it alot easier, but the price was and is about as much if not more than a new set of 555 etc. each to there own.
Do Creatd Motorsport offer cash back for your old injectors? :D
Deatschwerks offer:
R33 Injectors - ~$25USD each (~$190 AUD for a set of 6)
R32 Injectors - ~$12.50USD each (~$95 AUD for a set of 6)
Given that it brings the price down of the Deatschwerks injectors by a reasonable amount. (Down to the $300 bracket if I remember correctly)
Not that I know of. Rob just high flows the injectors you hand him. I guess the diff then is do you need 555cc or up to 700+cc. The prices then fall into line a bit better. Either way the prices are better than new retail so you can't go wrong.
  • 2 months later...
  • 1 year later...
ive just 'shaved' a set of known ka24de 270cc injectors, will rig up a test bench for these and pulse them to grab a pic of atomization.
then will be sent out to deatchworks to be cleaned and actual cc/min measured.
Ill be getting the rb25de injectors I have done this too tuned very shortly on a MT8 so I will post back with results.
I have some back up injectors there if it goes to shit but. See how bad the idle is.
Any updates?
i know this thread is old but im thinking its better off bumping this one then starting again.
I have a set of S15 injectors im selling, have been offered a set of high flowed injectors to swap, am i better off getting the S15 high flowed a little bit more (enlarging the holes if thats possible), getting the rb25 high flow items or just buying a set of 700cc injectors.
A lot of people from this thread should have had plenty of time to asess these, how many still have them and are happy with them?
  • 9 months later...
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
