  • Replies 182
Yeah i had a ball, pity about the weather.
Heaps of thanx to the organisers and also to Troy for putting up with me for a few laps, really appreciate it mate.
Bad luck to the wrx driver and to Matt, hope everything goes well for you guys.
Bring on the next one :/
I just heard about Matt from the driver of the white STI that was near him when it happened. Hope everything is ok mate.
Lets just say it could have been alot worse, especially judging by how that wrx turned out.
Bring on the next one :)
Thanks for letting me take it for a few laps. It was good fun...far nicer then my car would have been in the wet....and sorry if i talked too much, i jibber jabber :)
...sorry to hear about Matt. :/ Looking at his times though he was on song in the wet...really high up there. Shame it ended badly
Do-Luck!
I'm pretty sure i saw your car drifted very nice on the first coner :ninja:. You skid out a bit on the entry and instead of backing off you kept throtle open and start drifting. Well done mate.
Was that the first session? If so, that most likely wasn't me :happy:
I was in driving Simon's car behind you and Aaron. Im guessing your car has pretty stiff suspension and an aftermarket diff. Be great in the dry but in the wet it looked as though Simon's car had much better traction in the wet...looked good though with the thing doing slo-mo thtough corners sideways
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
