  • Replies 101
I'll come to lucky cup and see what the fuss is all about, will try to get team j-spec along too for the cruise... we might head off to the poker night tho after instead of staying for dinner.
didnt end up goin.
booked in on the 7th of febuary lol at burwood
il take the risk, i guess its local so it ISNT that bad
dude, just get an adult to come with you and supervise while you drive. Its not illegal for you to practice driving at night time... not like we're gonna be doing any super fun happy street racing, its just a social meet.
meh... its his problem if he gets caught or not. i must say though dude, thats pretty stupid.
happycup it is then. now if only some one can tell me where or what that is i'll put it in the 1st post. im guessing its the big carpark across from the station?
Map Link Happy Cup
Happy Cup's alright, its usually a meetpoint for locals with imports anyways... so just keep in mind you're in public and there's a police station nearby. Don't do anything stupid and don't try to be a hero on the street, we don't need any bad attention.
yeh it is, from memory its angle carparks.
is that where that computer lan thing was? EG or something
Edited by sillylankan
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
