Hey every one,
I got in to a bit of trouble today on the coast.
I lost control of my 32 and took out two parked cars :)
The whole left front and rear quater look more like a crumpled beer can than a skyline.
But dont worrie you should see the other two cars. Ahhhhhhh i guess its time like these all you can do is look on the brighter side of life hey?
Its a good thing ive only had the car for 2 months which is not in my name yet nor do i have insurance, other wise i would be really screwed.
Please laugh with me at my expence its the only thing keeping my sane.
Noza
https://www.sau.com.au/forums/topic/150654-smash-n-crash/
Daddy is not rich, im taking this one on the chin.
I went to over take a car that was doing about 20ks. When i hit boost there was another car that just turned, and is now heading straight on in front of me.
So when i pulled back into my lane (after over taking the slow one) i was doing about 70 and there was a car that stoped at a perdestrian crossing about 4 car lenghs infront of me. So i slamed on the brakes and the whole car drifted to the left and side swiped 2 parked cars.
Only having the car for 2 months im still getting the hang of driving a turbo.
https://www.sau.com.au/forums/topic/150654-smash-n-crash/#findComment-2804291
Yeah i stoped, i had no other option. There were about 30 witnesses.
I work in a law office, so i know exactly what im in for. (good thing theres over time this weekend)
The other drivers have all my details, i guess its people like me that give good skyline citizens like you all a bad name to the public.
Im sorry :)
https://www.sau.com.au/forums/topic/150654-smash-n-crash/#findComment-2804341
Well.... now we have nothing to rip into you about.... i was here for some entertainment :)
Haha no, well done that you stopped. You could have killed someone, i hope you realise that - learn from this one buddy, even if you know the law im sure you wont be able to get your way out of vehicular manslaughter or whatever the hell its called in Australia.
https://www.sau.com.au/forums/topic/150654-smash-n-crash/#findComment-2804347
now i know why i wont let my skyline out on the road without insurance too many other people out there that dont have it so at least in the event of getting hit my wheels willstill be repaiered without too much hassle
https://www.sau.com.au/forums/topic/150654-smash-n-crash/#findComment-2804352
yep it takes a little practice untill you're able to not mash the brakes in a crash stop situation. hardwire the notion that you don't have abs into your head
https://www.sau.com.au/forums/topic/150654-smash-n-crash/#findComment-2804394
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
