shouldn't be to bad.
just don't drive that hard. and when you next need to fill up put premium unleaded in.
I will for sure!!!
Man I must have been day dreaming I swear... Ive had my car for 3 and a half years... lol
lol, i know what you mean. Was with a guy that had just came over here from south africa and watched him fill his deisel 4wd with premium unleaded, just didnt click in my head. but unlike you his car was f*cked to drive after that. Thank god it was a work car :)
man thats tough...
I honestly dont know where my mind was............. lol
ok a bit off topic and sounds stupid but iv heard a couple of myths if you want your car to pop flames then put in unleaded in lol cos it will make you mixture rich and a rich mixture is what will let you pop flames lol :(
I did it once but i had no choice - the petrol station had no premium whatsoever.
I put just enough to get me to another servo to fill up with pulp. I did put some octane booster in for good measure. The car ran like garbage - backfired heaps, idled funny
I always double check before i put the nozzle in
Nulon Pro Strength Octane Boost and Clean. $21 from repco.
At least you didnt put petrol in a V10TDI Toureg. $25000 to replace pumps, rails and injectors. I have heard of a Toureg owner who did it paid the $25k only to have his missus make the same mistake 2 weeks later
eitherway the standard knock sensing will keep you safe.
it should, and i know there are some savages around who will flog their skyline on 91 RON and the engine seems to keep it together (not sure for how long though!).
My stock series 2 occasionally pings slightly on 98 RON, so I'd feel horrible about putting anything less in (had to use 95 RON plus octane boost once and it still wasn't brilliant). should have a look at the spark plugs sometime they're probably the factory originals :happy:
well give a boot full it will miss a splutter and or detonate.
engine may go bang lol.
nah but seriously it will be ok. just run the tank out and fill up with optimax.
lol putting petrol in a diesel car. had a guy in a brand new hiace D4 TDI who filled up with unleaded. that pissed out smoke. ended up draining tank. replacing filter. priming. remove filter prime again. and spend 30mins cranking...
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
