which option
18 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
here's the thing, i'm looking to a new project in the very near future and i have a big choice that i can't make a decision on,
i want a coupe to drive as a daily, i have the HR30 sitting here with only minor things to finish to get it on the road but i drive an r31 GXE with an rb25det in it and love the rb25det, i'm a huge r31 fan and love the club meetings/ cruises....
Do i go the rb25det conversion to the HR30 or sell the GXE buy a HR31 and convert that?
https://www.sau.com.au/forums/topic/150815-future-plans-ideas/
keep the r30... much better platform to work with, More classic styles, and lighter chassie :)
I like both ideas,
it would be easier to do the HR31... but
how many R30 monsters are out there? it would be an absolute weapon.
compliance/engineers would take a bit though...
i would buy the gear out of your R30( what you got exactly?) and put it in mine, :) and you could use the cash for the RB25 conversion!
I like both ideas,
i would buy the gear out of your R30( what you got exactly?) and put it in mine, :/ and you could use the cash for the RB25 conversion!
go the HR30 RB25DET it will turn alot more heads than a HR31 HR30's are twise as rare as the HR31's and just for the record im not baging R31's i love them just as much as R30's
... but
Weapon ???????????
Can't use anymore than about 350HP but an RB will do it a bit easier than my L series.
One day I might throw down the gauntlet and find out lol
Cheers, D
brakes are easy to upgrade without dr30 struts. Just use Hilux 4pot calipers, wtih 280z hubs. And a rotor to match. Im in the middle of doing this myself :wub:
i already have s-13 coilovers with r32 4pots and matching redrilled rotors on the HR30... :wub:
if i needed to upgrade i'd find a set of HR31 struts and work with those...
if i did go the HR30 way i'd have the speck to an engineer first about the body to see if strengthing and mods for the rb25 box to fit would be required, thier my only concerns with the HR30...
the other plus is that i'd have a very healthy budget to work with if i used the HR30, on top of this i could sell the GXE and i don't have to buy a project car....
Edited by rsx84
  • 4 weeks later...
Ok, plains are as follows.....
rb25det with matching manual conversion, r33 or r34 depending on halfcut costs....
DR30 rear end rotor to rotor....
New LSD....
5stud conversion....
New rims......HUSH HUSH on these......
new coilovers...
brake upgrade....
custom FMIC set up....
full 3" stainless exhaust....
new fuel system.....
a bunch of bolt ons and plugs ins......
interior dress up/ re-trim...
should be a real head turner as well....
i'm hoping a 6 month turn around from what it is now to something special......
New LSD....
new coilovers...
brake upgrade....
Good idea. SAme way im going :D. Hope to have mine done by christmass, Unless the missis gets knocked up :)
DR30 rear end rotor to rotor.... >>> Z31 slotted available from RDA
New LSD....
New rims......HUSH HUSH on these......>>>>> Probably another set of Watanabes & doesn't want to attract the heat :):D:(
new coilovers...
brake upgrade.... >>>> not Commodore pleeeeeeeaaaaasssse?
full 3" stainless exhaust.... >>>> stainless is a waste in other than mufflers
Check out my PM
Cheers, D
  • 4 weeks later...
Plans for mine as follows.. registerable pending:
RB26 single turbo conversion (otherwise stock)
RB25 Box
3inch mandral
bigger cooler
management yet to be finalised
300zx rear end(r200 LSD and brakes)4spot ZX up front with stud and offset conversion to suit 17's
half cage
sways, and strut braces
*Done and dusted, and will more than likely smoke some of the newer models out there with the powr to weight ratio..
$25,000 budget
New LSD....
new coilovers...
brake upgrade....
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
