Hey all,
Had a service done by Gavin Wood's Auto Tech on the Goldie.
Found out that one bolt on the exhaust manifold has been stripped.
Was also told that eventually the others will follow.
I'm thinking, would it be better to replace the exhuast manifold with an aftermarket item whilst the bolt is being removed? Or should i stick with the stock manifold?
Any advice would be great!
Thanks in advance :)
Edited by Logikal
https://www.sau.com.au/forums/topic/150835-exhuast-manifold/
Keep the stocker.
Manifold studs breaking is one of the most common problems.
If you only want 250rwkw (which is hi-flow terriroty) then the stocker is more than adequate.
Might aswell change all the studs while you are there mate.
you must replace the gasket.
also, do all the studs. otherwise you're just asking for more to break, they are 15 year old anyway!
I'd just use standard nissan studs. it will be another 10-15 years before you have problems again so don't obsess over which ones to use.
If you have to get a gasket [and that won't be from your local corner mechanic] then you may as well get the studs as well, try somebody like Just Jap or Kamikaze etc, from memory studs and gasket around $100 or a bit less.
im in the same boat...dropped the car off yesterday and the spotted the dud nuts straight away. im getting all replaced as well as my rocker cover gasket which was leaking...sigh. my clutch is supposedly slipping on the dyno so im in for a new clutch too. ah wells.
if you're really keen for a manifold upgrade, you might want to research up getting the stocker "extrude honed". they basically force through a gritty clay-like material through the manifold and this cleanes up the inside for more laminar flow. apparently very effective so i've been told
cheers,
Warren
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
