More individual tests and a couple professional tests will and would be good, as it broadens the range of tests done i say, but will clearly watch this page closely
  • Replies 94
Posted Images
maybe they should like alot BIN Numbers to them like penfolds red wines :D how many bins it took to get the perfect one. But aggreed, its trial and error to which batch you get/got
maybe they should like alot BIN Numbers to them like penfolds red wines :laugh: how many bins it took to get the perfect one. But aggreed, its trial and error to which batch you get/got
Yep we can compare it exactly to wine :)
ok as you know i recived my plenum a while ago got around to doin some work to it i have pics of before and after i will post up soon
well the casting was pretty average on the inlet ports they were a fair bit smaller in some cases which i can live with cause i had all intesion of match porting it anyways
i die grinded eveything came up a treat also clease up the water holes
i also cleaned up the inlet the inside was all pretty good wat you would expect form any plenum pretty much the same as my standard one
i then preped the top half of the plenum and grinded away the part where the greddy is normaly stamped
i then have sprayed it with this spray on bog stuff which give it a nice smooth fininsh only problem was i only done the top half not the bottom so that started to flake off cause of the crap dodgy silver paint that its painted in so im suggesting that you should get it diped n cleaned before any painting is done
i dont see how it will brake as it is structual solid no weakness
i can see improvment in air flow by a big diffrence but tune will only tell
all this was done in the matter of say 12 hrs (and i dont work fast lol)
pics will be up as soon as i can get them up
Thanks from the update, keep us posted :)
Just a suggestion.
I would not use any bog type spray on the plenum, as the aluminium expands and contracts as it heats and cools, which may result in cracks appearing in the bog, or the bog flaking off.
My mate had his genuine GReddy plenum powder coated, b4 install, and within a month crack were seen. The powder coater i/we use does awesome work and no cracks/faults on any other engine parts. My standard plenum is also p/c'ed and cracks can also be seen.
yer have progressed alot in fact is it finished but my camera died i have painted it gloss black to keep it well sort of stelth iov moved away from the polished look ill try n get pics up asap
i will put up my dyno result as soon as i can to might get it flow tested will its off
i spose you can i dont know much about the 32's im guessing the ports would be smaller but being a stock standard car i would not bother my standard manifold supported up to 280rwkw try and find one already done for a rb20
HAHA i hope these are the ones hydro'ing engines as the water port was taped into the intake runner..... if nto all good, i prefer the finish of the genuine ones but hey who am i to judge if it works. :P
Edited by URAS
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
